Nothing. If the response is flat to 100kHz, harmonic distortion is sufficiently below -75dB at all frequencies, noises and beats of all types are below the hearing threshold, square wave & impulse response reveal virtually no abberations or slewing, and there is no pre or post-ringing, then they will be performing identical. As such, they do sound identical. Beyond that, one may wish to look to ensure that internal components are adaquately chosen.Amplifier measurement that determine amplifier quality
We all know RMS power capacity, dynamic power capacity, frequency response, current capacity, output impedence and distortion are important measures.
What else is important in an amplifier. How can we tell an amplifier is of high quality based on hard engineering measurements.
I know that auditioning is needed to detect finer points of amplifier design. But here I am looking for things that can be objectively measured.
What can we measure in NAD and Parasound that is not available in Yamaha, Denon or Onkyo.
All properly designed amplifiers perform identical and faithfully reproduce audio waveforms to a degree of accuracy that is beyond human auditory descrimination. Those that induce high distortion belong in two catagories; substandard design and intended distortion. The sole reasons that audiophiles believe that their expensive big name amplifier sounds better or different at all from a HT receiver are entirely the effects of their integral auditory bias system. It's in their heads. An ABX test isolates the biases and will confirm this.
Now, there are several tests that are commonly overlooked by manufacturers, but one of the companies you have mentioned is flatly exempt- Yamaha. They put their designs under serious testing scrutiny, both empirical and subjective. In Tom Nousaine's paper, one of their mid-grade HT receivers was used in an independant ABX test versus a set of $14,000 Pass Labs class A monoblocks, and they were sonically indistinguishable to all those subjects involved in the listening test.
Here, the Sprint-Layout file.
There is much room for improvement.
regards Olaf
Thanks olafk
I think I can reshape this layout a little bit
can you mark where the jumper wires goes ?
from the top use S2 from Sprint Layout any
color is ok
thank for sharing
Juan
This indicates that you are a rational individual capable of critical reasoning. That is good. KEF's statement is to create a market. The extant fallacy in the speaker marketeer's claim is evident in that they do not attempt to identify what parameter wherein your receiver is supposidly lacking. Power? Only if the amp is being operated near clipping. To their credit, Yamaha designed some of the lowest distortion audio amplifiers ever made, on the order of good opamps today.This makes sense to me. But then I see a Yamaha selling for $500 with better specs than some of higher end amplifiers that cost $1500 or more. And I am told by several magazines that my $1500 KEF LS50 speakers need a much "BETTER" amp than current Yamaha RX-V800.
soundcheck
Some subjective impressions for comparison.
Sorry Mile, I meant A17 in my last post. I did not built the A23.
A17 and A33 are very similar in my ears. The A33 is highly detailed and a bit more beautiful in bass. But the difference is not great. And I could not run them at the limits.
I have heard compared to the A9. And if I could choose, I would like a amplifier mixed with an A33 and A9. A9 has a touch more of a tube amp. Especially in the bass has a little smoke, more profound, but in a pleasant way.
Can I be understood?
regards Olaf
regards Olaf
Thanks olafk
color is ok
thank for sharing
Juan
Did you mean this?
regards Olaf
A9 is my favorite I made similar amps AX9 and C9 and PSU40 for them.
You speak of average power that would be half of the max power which is 4.95W. I will research more about this
No power would be 2,5W max...
that's right - half of current does not mean half of power, because power is related in square to a current. for example,1/2 x 1/2 = 1/4...
Yes, I agree.
Might be a good idea, to design a A9 along with PSU as a compact stereo layout. But it would be nice instead of the BC550 to take another transistor, which one could better fit to the heat sink. The layout should be changed - but should not be a problem. Can you prefer one (MJE340)?
regards Olaf
Yes, I agree.
regards Olaf
BD139 will be ok,
hello sir
about selling PCB sir well .... actually is more in the diy side making them more as personal use to enjoy the build, I order a few PCB of the AX-14T "but .... as personal use" good thing that here in this sections many good people share the layout and with that we have many options to chose from, that make it fascinating
Juan
Juan
I would like to believe that for myself. But trying to be rational, I do not want to be ignorant. Also with so many people spending so much money, I don't want to blindly assume they are all ignorant and subject to hype. So want to keep an open mind.This indicates that you are a rational individual capable of critical reasoning. That is good. KEF's statement is to create a market. The extant fallacy in the speaker marketeer's claim is evident in that they do not attempt to identify what parameter wherein your receiver is supposidly lacking. Power? Only if the amp is being operated near clipping. To their credit, Yamaha designed some of the lowest distortion audio amplifiers ever made, on the order of good opamps today.
So if there are people in the audience who have actually compared yamaha, Denon and Onkyo with higher priced amps, I would like to know what they found. It will be really useful to me and thank them in advance.
great job,Olaf and Mile!
i was rude enough to copy your work to our local forum (i also aded direct link to your post there),and i sincerely hope that someone near me will build your pcb of A33 so than we could compare A23 with A33.
thank you so much for effort you invested in drawing visually simple PCB,and for testing it. great job for all DIY comunity,greetings for Mile and you Olaf! great job...
Hi, here are the layout-files for the A33.
Please do not forget the wires between the points marked as A-A, B-B.
Much success and have fun.
regards Olaf
You should start your own thread with these questions. This thread is about Apex amps which are DIY. You will get far more folks looking at your questions.I would like to believe that for myself. But trying to be rational, I do not want to be ignorant. Also with so many people spending so much money, I don't want to blindly assume they are all ignorant and subject to hype. So want to keep an open mind.
Good news,my A23 amplifier it's playing nice , but it's to late to give volume on input ..... Until tomorrow, some pictures . Rail voltage only +/-36V for testing . Offset voltage after 45 min, +27 mV
Regards ,Alex
Regards ,Alex
I hope we can see pictures when next A33 is built
regards Olaf
- 100W Ultimate Fidelity Amplifier
