CAPS LOCK= shouting - try to use only for dramatic emphasis as required
Dayens Ampino is a nice sounding little piece, and yes, the source is important, but there's a big matrix of possible permutations of upstream components, and perhaps few here who will have heard the exact combination you describe.
We could prejudice your assessment with a range of broad generalizations of the differences to expect, but I think it'll be far more enlightening to listen with an open mind.
Keep in mind that regardless of amplification or enclosures used, Mark's drivers require a break-in procedure that is well described in several threads - this one as good as any
http://www.diyaudio.com/forums/mark...ecommendations.html?highlight=driver+break-in
What would be a good build for my first set of Alpair 7a3 s... Dan
Aren't you supposed to building the FH3's?
jeff
How about one of Dave's Mar-Ken boxes: http://frugal-phile.com/boxlib/P10free/CGR-dMar-Ken73-301113.pdf
jeff
jeff
or something that I can make really quick to start the break~in process...
Cardboard box?
I just set the drivers face up in the "closet" for initial breakin.
dave
- Full Range
- Advice for driver
