I thought so(the marking doesn't look good), but maybe it is original one...
I saw at post #3317 there are AX-14 also use jengkols (with better marking)
but don't worry I have spares some old motorola 15003-15004 if this one is blown
I will try at rail +/-55VDC for 8 ohm load, is it is okay?
if they were original I believe they wont failit is worth to try
I just realize it ... & I will try to redraw it if needed& fortunely I have some LM4562
No need to redraw...
Very first draft with mirrored output transistors. Can someone check it please?
A schematic would be very helpful.
regards
I see a inverted 1N4148 make sure all is corrected before you continue, I think the original layout look good no need to redraw
Juan
regards
Bias transistor must be replaced with BD139 or MJE340 in your pcb.
Sorry,here are some picture of AX-11.
Zoky2
Nice work,
A17 CFA
Hello Mile,
thanks for schematic. I will check the layout and then build a version.
For what other transistors you recommend a heat sink or mounting on the main heatsink?
Thank you for a new amplifier
![Ho Ho Ho :hohoho: :hohoho:](https://files.diyaudio.com/forums/images/smilies/hohoho.gif)
regards Olaf
Hello Mile,
Thank you for a new amplifier. Feels like an early Christmas
regards Olaf
A9 CFA
thanks mr mile, and what psu recomended for it, vac dan vaA17 new pcb
Outputs and bias transistor are from botom side of pcb... A17 use psu and protect same as AX11.
- 100W Ultimate Fidelity Amplifier
