Studio Reference Amplifier
:D ....
...... sorry , was modified so many times ..... forget to make connection ;) but the silk screen it's the same . In the post#707 it's correct ......
Alex.
sir alex and all diyers i need your help pls. i build 1 pair of S200 rev.3.1 but i encounter the same problem. the 10 ohms 2 watts resistor next to the inductor coil SMOKE comes out sir too hot...pls. help. i powered +/-42 volts DC SIR. MORE POWER AND GOD BLESS..
Hi desertstorm.
Remove fuses.Replace them with 2 resistors. 10-22R.
Power PRIMARY side of transformer via 220v lamp.in series.
If the lamp glow remove the power cord and examine all the circuit for wrong placed parts or short circuits .
If lamp is dark you are on the right way.
Measure voltages on test resistors(these in place of fuses)you must see low voltages about 2v or something about it.
If you see high voltages ,something like 5v there is a problem.You must examine for faults again.
Suppoce you measure 1-2v.Measure amplifier out ,you must see 0v d.c or something as 20-100mv d.c.
If you measure 42v you have a problem.
If you measure 0v or 20-100mv d.c measure again but for a.c volt .
If you measure any A.C volt here(without any inp.signal)your amplifier oscillate
Hope these are usefull.
