Ok,Thank you pcb doctor!OK no problem .....
Regards Alex
What pcb ver.is this?
alex mm can answer
Hi Mile,
I am building this right now. How critical is the 4K4 at R7/8, R9/10? Can I use 4k7 there instead? Also, what other IC chips can be used for the servo?
Thanks, Terry
Use any value from 2k2/2W to 4k7/2W... for +/-50V rails I sugest 3k3/2W.
For DC servo many IC chips can be used: TL071, TL081, LF356...
What you have gerber file for my sr200 apply to Sanken v3.2.....yes of course , why not , here in attachment are all files for toner transfer metod
Regards ,Alex
Regards.
thank you very much Alex could give me a layout file is not sorry to bother you because I am not proficient in layout.....sorry the gerbers files for SR200 v3.2 are not available .... I have send you private message ! I have a bug in program and generate gerbers with errors , this is the problem .
Regards ,Alex
Regards,Duy Minh
Can we see this in pdf or jpeg? Is this posted somewhere in this thread?....sorry the gerbers files for SR200 v3.2 are not available .... I have send you private message ! I have a bug in program and generate gerbers with errors , this is the problem .
Regards ,Alex
...... sorry , was modified so many times ..... forget to make connection but the silk screen it's the same . In the post#707 it's correct ......
Alex.
sir alex and all diyers i need your help pls. i build 1 pair of S200 rev.3.1 but i encounter the same problem. the 10 ohms 2 watts resistor next to the inductor coil SMOKE comes out sir too hot...pls. help. i powered +/-42 volts DC SIR. MORE POWER AND GOD BLESS..
Hi desertstorm.
Remove fuses.Replace them with 2 resistors. 10-22R.
Power PRIMARY side of transformer via 220v lamp.in series.
If the lamp glow remove the power cord and examine all the circuit for wrong placed parts or short circuits .
If lamp is dark you are on the right way.
Measure voltages on test resistors(these in place of fuses)you must see low voltages about 2v or something about it.
If you see high voltages ,something like 5v there is a problem.You must examine for faults again.
Suppoce you measure 1-2v.Measure amplifier out ,you must see 0v d.c or something as 20-100mv d.c.
If you measure 42v you have a problem.
If you measure 0v or 20-100mv d.c measure again but for a.c volt .
If you measure any A.C volt here(without any inp.signal)your amplifier oscillate
Hope these are usefull.
- Studio Reference Amplifier
