I ordered 8 and 7 are o.K.
One had an incredible high gate leakage. I just try to build a nice 10W SE amp using as starting point the Amp Camp circuit. For the upper part a SS R100 is used.
I still fight with the problem that the distortion figures only come down to 0.7% when I mistune the output node voltage not to half of the PSU voltage but
considerably higher, means much wattage for the SIT and less wattage for the SS.
And I still do not know why, if I find the reason or someone can tell me.........
I would be very happy....
In that case, the offering from Sun-Pec is a bargain.
Good news ! Thanks gentlemans
Juanitox can sleep on his two ears
Single-ended giant SIT amplifier very interesting
fun is in the details ?
http://www.src-el-main.com/SIT_web.pdf
Best regards
a high current tube rectifier will drop a lot of voltage, waste of power , and add of heat ... we are hot enough with the 2SK82 tube rectifier are nice with low power low cap value in the power supply but with 100000UF CRC who really cares rectifier sound ?
Hi Juanitox
By diyer curiosity you ready made PSU with CLC.
Choke in psu what real benefits for music ?
In this case Ironamp with choke filtered be one ultimate all irons
My big 100 000 uF caps is only max 50V rated think i connects him in series
Calculate the total capacitance Ct = (C1 x C2)/(C1 + C2) for voltage needed.
Other question : do You have experiment in L'Amp
change resistor to little choke in signal path if yes what happen ?
Greeting :
slow down le french!
i have mase a CLC with theinductor sit amp , better than a CRC but don't forget this amp run at 2 Amp .. so the chokes are big ..
for the ironamp just make a power supply like you would do fir a powerfull tube amp "just" 350ma here. but far the caps it"s 160V minimum
What was the leakage and what were the voltages and currents?
Hm, I threw it already away....
I try to remember....
In the curve tracer from locky-z the part behaved normal.
But in vivo it sucked the gate bias voltage, normaly going from 5V to 0V away,
I could not control over the gate voltage the drain bias over the level all the others did.....
Sorry I do not remember better......and I excuse for un precise explanation.....
CLC....better than a CRC
for the ironamp ....far the caps it"s 160V minimum
Némésis amplifier have psu with choke too
100 000 uF caps 40V max tension rated is easier to find.
For Ironamp if must be 160 V this is huge voltage rate !
What be minimum total psu filter capacity for nice mono block ?
Greetings
Hi Diyers
Ironamp mono block made by sir Mike
are without big caps in psu ?
Anyway look are toobiest too
me adore his blue-print style
Hi Zen Mod
Yeah sir Mike have designer talent !
Let´s see some more and big Tokin sit with Sony
ZM do you have confidential news about update of update ?
Best regards
Show your handlebar mustache
Ironamp is only for mens with handlebar mustache ok.
I have secret lab and goggles but not mustache.
I start grow my to be into diy project
Yes pictures of amps and mustaches !
Handlebar moustache - Wikipedia, the free encyclopedia
Hi Diyers
Mr Mike Rothacher show mustache on his blog :
Audiohobby.com | DIY Audio Projects & More
Thanks for new update with psu schematic and bias
This prepare me start to build one Ironamp step by step.
Have a nice day gentlemans
i have received my pair from sun-pec , what to measure to see if they are in working order and real Sit ?
Hi Juanitox
Can you share information about Tokin sit´s
from Sun-Pec all is ok or fake refurbished ?
Thank you very much !
Greetings
One problem I see, out of 12 i had on my table there are two that seem to have too high gate leakage.
Today I build in one that showed with 1A6 at the 47k gate biasing resistor 1V75......
So ........ some surprise included......!
I will write them.....will be interesting what they will answer.....
stop the blahblah!Hi Juanitox
Greetings
it's time for you to build something with the 2SK82 , so much way to do it , single ended , pushpull, active load , choke load , resistor load ,bulb load . fixed bias , source resistor bias , etc...
you 'v got many days of happiness and headache with it.
and let the big boys play with Tokin Sit ( i'm not included)
Mike R. gave me in a private e-mail the hint that 1.75V/47000R gives a current of 0,000037234042553A.
So we have only 37 uV gate leakage. Under 100uV is o.k.
Sometimes I write nonsense, sorry!
The truth is more that I had only 4V bias voltage available and taking these 1.75V away I could not adjust the drain bias to the wanted level.
So at least one SK180 is not so bad as I thought.....
Long live Sun Pec!
And thanks Mike.....!
- Ironamp Video Posted
