Vacuum Tube SPICE Models
Making slight headway, the Koren model I used came from Intact Audio, that's why the curves were different from yours:
Code:
.SUBCKT 6SN7GTB A G K
XV1 A G K TRIODENH
+PARAMS: LIP= 1 LIF= 0.0037 RAF= 0.02 RAS= 2 CDO= 0
+ RAP= 0.002 ERP= 1.4
+ MU0= 19.2642 MUR= 0.006167 EMC= 0.0000189
+ GCO= 0 GCF= 0.000213
+ CGA=3.90E-12 CGK=2.40E-12 CAK=7.00E-13
.ENDS
jazbo8, that's one of Duncan Munro's models. :D
popilin, here's a 6SN7 model I made using Curve Captor:
Code:
* 6SN7_GE LTSpice model
* Modified Koren model (8 parameters): mean fit error 0.0771164mA
* Traced by Wayne Clay on 10/11/2013 using Curve Captor v0.9.1
* from General Elctric data sheet
.subckt 6SN7_GE  P G K
    Bp  P K  I=
+ (0.01996138472m)*uramp(V(P,K)*ln(1.0+(-0.06003194624)+exp((4.721146098)+
+ (4.721146098)*((20.78010878)+(-111.9910206m)*V(G,K))*V(G,K)/sqrt((29.06231184)**2+
+ (V(P,K)-(6.821890538))**2)))/(4.721146098))**(1.378722311)
  Cgk G K 2.8p ; 0.2p added
  Cpk P K 2.2p ; 0.5p added
  Cgp G P 4.5p ; 0.5p added
  Rpk P K 1G ; to avoid floating nodes
  d3  G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends
It follows the General Electric data sheet almost exactly...
Hi cogsncogs
Good to see you around here !
Your model looks very very good, and yields about -50 dB 2nd with Morgan Jones circuit, very very close.
As usual, your models beat any other. ;)
Administrator
Joined 2004
Curve Captor is just another way to capture tube curves, latest version is here:
Curve Captor | Free Science & Engineering software downloads at SourceForge.net
I've not used it in the last few years.. (It is very good for tracing triodes and runs under tcl in windows or linux - last time I used it.) I will probably be using it again in the future.
More details here:http://www.diyaudio.com/forums/tube...be-modeling-software-beta-testers-wanted.html
I had a brief flirtation with this and paint_kit for triodes, and paint_kip a few years ago, and then did not need the functionality, had some computer meltdowns.. Having bought and built a uTracer early this year I now have the motivation to use tracers again as I have not had much luck with pentode models generated by the uTracer alternate gui - I'm probably doing something wrong..
Hm-m-m-m, unfortunately I do not run Unix (PC w/MS Vista), nor have access to those ancillary programs mentioned.
While I have been wanting to get into using something like LTSPICE, I would just as easily prefer dumping everything (equations, constants, variables) into a spreadsheet and use the plot function to create the resultant curve graphs.
General Q: Is Curve Captor better/worse/same than Model Paint Tools?
Administrator
Joined 2004
I get good results with the latest versions of paint_kit, and paint_kip. I've not reevaluated Curve Captor recently so can't say, the last version I used worked quite well..
Paint runs in java from the command line in windows and has a nice gui.
Curve Captor runs in TCL which is available free from a variety of sources on the web and runs just fine in Windows last time I used it.
All of this software is free for personal use, some is open source and free for any use.
For diodes and triodes, I prefer Curve Captor.
You can trace directly from data sheet Plate Characteristics curves, Grid-Plate Transfer curves or enter data directly from csv, spreadsheet files etc.
Simulate load lines with calculated THD from 'captured' curves.
Model types:
Child-Langmuir law
Child-Langmuir law with contact potential
Rydel model 4 parameters
Rydel model 5 parameters
Koren model 4 parameters
Koren model 5 parameters
Modified Koren model 6 parameters
Modified Koren model 8 parameters
Outputs to: 3f4 Spice, PSpice, LTSpice and CircuitMaker.
Ex-Moderator
Joined 2011
Ip-Eg curves can be derived from Ip-Ep curves, and follow the "same" 3/2 power law, so curvature meaning is the same.
That's true for the Ayumi model but perhaps not the Koren model which uses the generic diode SPICE model.
I don't find any difference with this FFT analysis -- the amplifier is basically SY's "Impasse" using the optimized Koren model, and the Ayumi model:
Does the Impasse use LEDs for biasing the bottom triode?
I just assumed that everyone use the drop-down tube manual in LTSpice from Intact... Thanks for the clarification.
You're kidding, right? :D
Here are the parameters from the optimized koren model -- of course there are a lot of moving parts so there are a lot of optimal solutions:
Params: MU=21.54 KP=133.1 KVB=350.9 EX=1.378 KG1=1445
I use graph-grabber for capturing data
SY's ImPasse
6SN7 Koren model
2nd -65 dB THD 0.054%
6SN7 Optimized Koren model
2nd -60 dB THD 0.095%
6SN7 Ayumi Nakabayashi model
2nd -51 dB THD 0.26%
Again, with Norman Koren model, THD is close to 0.04% at 20Vp claimed by SY.
SY's ImPasse 2V RMS
6SN7 Koren model
2nd -82 dB THD 0.008%
2nd -77 dB THD 0.014%
2nd -68 dB THD 0.037%
Again, with Norman Koren model, THD is close to 0.01% claimed by SY.
Ex-Moderator
Joined 2011
12BY7A Model
Someone on another forum pointed out that the 12BY7A model in Ayumi's pctube package is far from accurate, so I tried to make a new one, but the result is still so-so... If you have a better one, please post it.
Code:
* Generic pentode model: 12BY7A_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Fri Dec 27 09:04:07 2013
*                 Plate
*                 | Screen Grid
*                 | |  Control Grid
*                 | |  |  Cathode
.SUBCKT 12BY7A_AN A G2 G1 K
BGG   GG   0 V=V(G1,K)+0.65943158
BM1   M1   0 V=(0.012147484*(URAMP(V(G2,K))+1e-10))**-0.63410138
BM2   M2   0 V=(0.70287195*(URAMP(V(GG)+URAMP(V(G2,K))/24.460049)))**2.1341014
BP    P    0 V=0.0067627064*(URAMP(V(GG)+URAMP(V(G2,K))/34.80015))**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0039175034*V(M1)*V(M2)
BIG   IG   0 V=0.0033813532*URAMP(V(G1,K))**1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4)
BIK2  IK2  0 V=V(IK,IG)*(1-0.4*(EXP(-URAMP(V(A,K))/URAMP(V(G2,K))*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.82100762*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))**1.5+0.17899238)
BIK3  IK3  0 V=V(IK2)*(URAMP(V(A,K))+5958)/(URAMP(V(G2,K))+5958)
BIK4  IK4  0 V=V(IK3)-URAMP(V(IK3)-(0.0036749321*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))**1.5))
BIP   IP   0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.0036749321*URAMP(V(A,K))**1.5)))
BIAK  A    K I=V(IP)+1e-10*V(A,K)
BIG2  G2   K I=URAMP(V(IK4,IP))
BIGK  G1   K I=V(IG)
* CAPS
CGA   G1  A  0.063p
CGK   G1  K  6p
C12   G1  G2 4p
CAK   A   K  3.5p
.ENDS
I have a certain amount of new/unused C3G. These are top class small signal tubes.
For most of them Ayumis model is perfect (both, pentode and triode model).
However, one third of my C3G`s has a totally different operating point which has no logic with data-sheet.
A similar story is with E80L, E180F ...
I am inclined to the opinion that the difference in the models is less than in the tubes of the same manufacturer.
