Dx Blame MKIII-Hx - Builder's thread
Fitter maybe,me personal don't like those big caps direct on the boards due the charging currents,I could be wrong.
Yes i would use the brute force in the PSU and have smaller value on the boards, nearest to outputs , 5000 uf each close to outputs is good
As I can recall 9 Euro a piece by 70 boards ordered
Is this the 4Pr or 5Pr outputs ...? that's a lot less than the original run of boards ....
Finished etching my board
I finished etching my and drilling my board.
meanman1964,
I've been working on populating the board. I noticed I had a missing track for R08A to R08B. I also increase the hole sizes for some of the electrolytics. Attached is a PDF with some of these corrections.
  • DX Blame MKIII HX output 2013-07-13-a.pdf
I finished installing all the components on the board using my layout and turned on the amp using the lightbulb tester and no load connected and a +/- 40V power supply. The lightbulb flashed as the caps charged and then went out, but I see +35V on the output without any input signal. The oscillocope shows DC. The good news is it provides another "learning opportunity" for me!
So far, I've done the following in-circuit checks with the amp powered off:
* Set VR midway
* No short to heatsink for output transistors
* Inspected soldering and did continuity check--did not find any shorted tracks
* Verified correct transistors installed in correct locations
* Diode check Q12 ok (b to c, e)
* Diodes 1n4007, BAV21 ok on diode check
* Checked all transistors, no shorts
* Did not note any unusually hot components or observe any obvious physical damange such as scorched/smoking resistors or capacitors
* Checked resistor value R10-correct 2k2
* Checked orientation of electrolytics-ok
* Checked continuity of rails to OP transistors: only saw continuity with collectors as expected
