Roender's FC-100 prototype and builder's thread
Thanks for your thoughts Rudi :)
This evening some friends came to me to listem FC-100 and some DIY speakers and i've used FC-100 without covers and the bias swing was not so big. It remained around 37mV.
Before my new NJL arrives a will optimize the air circulation installing some small fans on the back of the case and i thinks a will survive like this.
Just to show you some quality differences between 2013 transistors vs older production date transistors:
Vf diode for NJL0281:
2013 samples:
0,508
0,507
0,506
0,509
0,509
0,506
0,506
0,507
0,505
0,507
2012 samples or older:
0,518
0,521
0,518
0,548
0,522
0,524
2013 samples:
0,508
0,507
0,506
0,509
0,509
0,506
0,506
0,507
0,505
0,507
0,518
0,521
0,518
0,548
0,522
0,524
This doesn't mean that ONsemi has done something wrong with newest Thermal-Track transistor unless TC is different than -1.66mV/grdC. If it is, then other diode is inside the transistor case, not what was used in the previous production batch.
If the diode Vf is less than 0.52V but TC is the same batch to batch then only a simple adjustment of the series variable resistor into the FC100 diode string will bring the bias to the desired level. If the TT diode Vf is much bigger than 0.5V then nothing could be done if the bias at the zero adjustment point of the variable resistor is greater than designed value.
Hello,
Here are some pictures of my finished amp.
The Lightspeed Attenuator is integrated as well but I have the option to separate it.
So it´s easy to try things like an amp or pre-amp.
Thanks to Rudi for his support!
Andreas
@atupi
On the picture you can see how it works.
I took 2 Conrad heatsinks (350x150x60mm), 8 Aluminum angles and a plate of 3mm Aluminum.
The plate doesen´t reach the heatsinks there is a 10mm slut.
With the holes in the top plate there is enough air circulation.
At first the amp has to play some hours.
Later I will write something about the sound in comparsion to an Aleph J and Symasym (at this moment ...).
Andreas
I've recognized Rudi's ideas ;)
Smart move with that 10mm clearance. I will post some pictures in few days when i will have everything installed inside.
What about grounding scheme? I know there are different approaches, my case is not connected to the FC-100 right know, what would be the best solution ?
@atupi
Andreas
Eager to hear your findings.
Guys,
Your builds looks gorgeous.
This is mine, more than 5 years old now.
The pictures that doesn't represent RMI-FC100 are from my work in progress project :D
yeah, you're telling me
i got one for a preamp on "ePay" some years ago and have not been able to find one easily in the USA since.
unfortunately, nothing's changed as far as i can tell.
mlloyd1
It's VERY difficult to find off-the-shelf R-cores in North America, or even elsewhere with 120v primaries. I even tried doing a custom order several years ago, but quit in frustration with Chinese "English".
I am not aware if the situation has changed since then.
