I only changed to the LM4562 in a couple of PC soundcard and the sound came out clearer.
I changed all the regulators in the PSU (DVD3910),but I´m not sure about the outcome..(soundwise).
Truthfully,there are so many good dacs out there at reasonable prices that it becomes ludicrous at times to mod the audio path when you can just come off the transport into a DAC...I will try it tho.
Thank you very much for the help bro
I appreciate it
I'll put lm 4562
Another question if you can
You also recommended switching capacitor in the circuit ?
and what brend ?
In the switching capacitors,I would use Nichicon muses..They are perfect and priced reasonable. Truthfully,the logic switching circuit is not going to degrade or improve your audio...That all is done the audio path itself.
you now thet when you use digital output dsd is convert to pcm
I know.
Because I use the digital output.
I use the digital output also .
I did not understandThat "cap" is maid up of 5 singled caps you would have to use this formula to calculate the new value f=1/(6,28xRxC) (where R is 30k) of a single cap.
What do you mean
Capacitors 1 worth 5
Can you give me new values of the capacitors if I replace
You mean two capacitors in AUTPUT STAG Large capacitors electrolyteIf you use a "plastic" cap with the value of 4.7uF you get the -3db point of 11hz.
It all depends on how much you are willing to pay for 2 caps.
I have got no experience of plasic caps,so If sommeone who has are willing to advise.
Can I replace the electrolyte capacitors 100uf-50v in the audio unit circuit
weth
NICHICON muse-kz series 100uf 50v
They are not expensive and I've heard they are good
What do you think ????
And it says 1000 hours
It seems a little odd
Capacitors for quality
weth
Yes its the 2 brown elyts,and yes you can use muse-kz,but I would wrather use sommething like this maybe 10uF Mundorf Film Caps EVO - Aluminum + Oil
100uf is cost 80 $Yes its the 2 brown elyts,and yes you can use muse-kz,but I would wrather use sommething like this maybe 10uF Mundorf Film Caps EVO - Aluminum + Oil
160$ for 2 cop Expensive
Why did you write 10UF ?
Now that the device capacitors
c 363
c 361
CE04W1H101MT(ASF)
100uf ?
this the capacitor I think I will buyWell you can use 100uF e-lyts if you like.
NICHICON - UKZ1H101MHM1TO - CAPACITOR ALUM ELEC; 100UF; 50V; 20%; RADIAL
CAPACITOR ALUM ELEC, 100UF, 50V, 20%, RADIAL
LCR COMPONENTS
FSCEX 6800PF 1%160V
LCR COMPONENTS
FSCEX 1000PF 1% 250V
LCR COMPONENTS - FSCEX 470PF 1% 630V - CAPACITOR, 470PF, 630V
Because the 100Uf is oversised,you relay don´t need more than 10uF to get an -3db under 10Hz.Why did you write 10UF ?
And Mundorf Film Caps EVO - Aluminum + Oil
is of a better quality than an e-lyt,but a little more expensive.
But its up to you.
You decide.
- Digital Source
- denon dvd-3910 service manual ?
