MPP
http://www.onlycreative.it/en.html said:
Technical specs
Power input 230/400V 50/60 Hz 800 A
Power supply 6400 Amp - 1.000.000 mF
Output Power 2 x 60.000 watt RMS Class A
Output multi. 6 x 20.000 watt RMS Class A
(Max output power 160.000 watt)
The power output was measured during a gigantic-ones-in-a-1001-centuties thunderstorm of the 666th kind, there are no written reports, most scrolls where burned in the aftermath, only one word could be read, 'F*c?'. At that time the 'power-input' figure was made by method of guesstimattion.
Spaceships, of the 'Flying Saucer' kind, passing by reported 'NOTHING' (this I got from a reliable source). The guys from ATL deny all.
I do not think that 156uF/Amp is enough for any amp was all the reported.
Super quality build... maybe you could give us a hint on the basic topologies used.....
O.k. here it is :) one 'Transresistance CFB BIGBT Amp, By FdW'
