Salas hotrodded blue DCB1 build
Joined 2011
It looks like it does not pull much at all...
The button probably contains an ordinary LED and has a built in resistor for 12 V feed. 10-30 mA would be my guess. Do you feed the power on LED with that, and kept 2k2 resistor? Then I guess it doesnt light up the house? And you could measure the current by taking the voltage drop over the 2k2 res.
/Staffan
I am leaning towards hooking up both the Illuminated power switch and the VU meeter board to this spot:
I do have a heat sink coming for the 7812... I am buying a kit from Teabag. Having the heatsink on the 7812 perhaps I can push having both the Illuminate power switch and the VU meeters? Salas mentioned this 7812 is the breaking point I think...
Joined 2011
To my knowledge a 7812 takes well over 1 A sinked. You see were you have gnd. Its the copper lane that connects the centerpin of 7812 and the power on LEDs cathode. Between LED and the 12 V output from 7812 output pin you have a 2k2 current limiting resistor.
Dont think the copper lanes are designed for 1 A tho, but that you wont need.
Staffan
Joined 2011
PS - Teabag has upped the capacitors on the kits to 10,000uf 35v from 4700uf 25v... Not sure if that added capacitance changes things..
Not in this case but its a good thing for hotrodders who does 2*15 V trafos. 25 V is licking its limits there since its ripple on the ingoing rectified 21ish voltage. Sure it is 2 times 10 000 per rail? They will most likely be big.
Staffan
Cool...
I was planning to do two sets of output using the Salas advised "100 Ohm buffer resistors Y split" This VU board has a R/L channel input...
So would I do the Y split on the two sets of RCA outputs and then run a 3rd set of outputs to this VU board I think
So I'd have for a channel output off of the DCB1 3 lines out. I'd Put 100R in line with each output RCA. Think I should run a line direct from the DBC1 to this VU board or should I put a 100R inline here to the VU as well?
Joined 2011
A question about CCS differences due to PMOS/NMOS Vgs differences. I had less currentdraw on the negative rail on all 4 cards, as mentioned before. The relation is about the same on all cards. Putting a 56R over 10R on negative side makes about 8,4R measured and that about balanced it out. That makes a relation 8,4/10.
Do you think this relation will stay if I grill each side a bit more? I was thinking to buy some 3,3R and 4,0R caddocks, but they dont come free.
best regards
Staffan
Joined 2006
best regards
Staffan
I beleive Salas voiced it, or deemed it to sounds better out of balance this way ---- but it may not to you.
BTW, this issue occurs in the SSLV1.1 boards as well, but there you want to correct it.
diyAudio Chief Moderator
Joined 2002
To exactly balance the main CCS currents (offsetting the PMOS-NMOS Vgs dif in essence) is mostly perfectionism since the Gfs of such MOSFETs does not vary appreciably for few decades of mA dif even. But perfectionism achieved gives satisfaction and peace of mind which is a welcome factor to any hobby.
