Kerfs ...
.... recommend them at panel edges.
WHG
>snip<
>snip<
CHeers
WHG
WHG
How do they help ,new to wood work .
The joinst will be filled and sanded then the cab's HiFilled ready for painting .
Cheers
Mal
Even plywood will move a bit. What WHG proposes is a way to keep the attractive aspects of the corner(s). The quirk doesn't have to be physically large ... just enough to look like it belongs there. Nothing like checked filler to ruin a paint job ... as I'm sure you know. ....and you've doubled the chances (two joints per corner).
Kerf
In addition to puppet's answer, they also improve enclosure aesthetics.
Recess the panels slightly to avoid snagging the veneer.
WHG
Cheers
Mal
WHG
Dry Fit
Today screwed around with the front corners today made a mess of one so that will be used on the spare pair of cabs .
I'ved screwed together the sides to the base to see how it all fits ,thank god for filler and polyester spray filler .
Theres about 2mm extra in the radius to be sanded flush with the side panels .
Cheers
Cheers
If it were me I would upscale the bracing into full intelocking shelf braces, especially with the wall thickness you have selected. Is there a reason you are going with a low rigidity cabinet? Do you intend to include extensional damping?Started on making some of the bracing .Its 22mm & 19mm dowel
Cheers
E-A-R Specialty Composites
IME mass+stiffness+damping is the proven way to make an enclosure "quiet".
Constrained layer damping is superior but is precluded by your construction method.
Hi
Today a couple of mates came over and helped finishing off the bracing and fitting the top & bottoms panels .Ports fitted next couple of job's to do trim the top and bottm panels sand the sides and glue on the alloy skin and finish the front baffle area .
While we had access to the internals we measured and cut the Black Hole 5 sheets .Didn't have time to glue them in because I sealed the internal walls with Bond crete was still drying off .
Cheers
Cheers
Real nice build.
Beautiful work as always mate! It's always interesting to see how these crazy bits come together to make sense in the end.
Thanks guys ,the project will slow down this week I'm due back at work Monday . Work just gets in the way .
CHeers
Finally the CAD drawings come to life!
Looking really good, the bass boxes are coming up a treat. Any luck might be running before christmas.
Which Christmas?
- 4 way active ,passive or what works best
