Three Transistor push-pull amp
  • AMPLIFICADOR EN CONTRAFASE PUSH-PULL DE TRES TRANSISTORES.zip
scheme
I upload a picture to be more didactic.
I'm afraid you will get high distortion.
But the circuit will work.
Big problem can be when using 8 Ohm loudspeaker. Circuit shows 25 Ohm.
If you use 32 Ohm, or more, headphones it might work okay.
But you can count on rather high distortion anyway.
