I think it's time you stopped posting designs that are not yours to post, especially since you do not give credit to the original designer or publisher. It is very obvious to me where that one came from.
Tell me Mr.12E1 what's original?
thank you!
thank you!
One where you didn't cut and paste someone else's COPYRIGHTED image. This is dishonest.
If you copied it, it isn't original. Difficult concept?Gost22 said:Tell me Mr.12E1 what's original?
Gost22
Can you specify a Hi-End preamp ?
Just list the features.
For tube preamp or in general?
Hi SY!One where you didn't cut and paste someone else's COPYRIGHTED image. This is dishonest.
I did not copy it!
You copy it that is making this tube pre-amp with 12AX7 (ECC83-Philips mini WATT) and you will hear the true valve sound, which is called transcendental
Enjoy the real tube sound!
Tube pre amp.
Tube pre amp.
Yes, tube or valve pre-amplifier!!
Firstly it gives the true tube sound, not the of transistor sound cold without a soul ...
That its characteristic design-nice for the eyes!!
Orchestra to convey to you as a concert etc. ...
Cheers!
Hi SY!
I did not copy it!
Yes, you did. That is not a drawing you created.
Yes, he took part in creating!
Here is a picture of the tube pre-amps (Figure 1).
Cheers!
Do you think that using any sort of negative feedback in tube preamp will make the tube sound disappear ?
Negative feedback is minimized (catode resistor R11)-view schematic tube preamp with 12AX7Do you think that using any sort of negative feedback in tube preamp will make the tube sound disappear ?
thank you!
Will not disappear, but a lot is lost.I know this schematic.
But you did not answer my question; does the tube sound disappear if negative feedback is used?
Try it and you'll see what's the matter
I have tried many times but never noticed that.
On the contrary, NFB has allways improved the "sound".
I've seen it before as well- can you recall the source (I can't offhand)?
Elektor magazine or one of their books / CDs I think.I've seen it before as well- can you recall the source (I can't offhand)?I know this schematic.
- Tubes / Valves
- High-End Tube preamp with ECC88
