Mic, Line, EQ... Preamps
ML3
hi apexaudio
i wanted more frequency control adjustments
can i add more ic circuit module(like picture) for another frequency adjustment ?
i am wanted to add 3 more frequency controls(total 6 control) .
please help to modify ml3 circuit.
thanks & regard
have you tried it? for how many volts and amperes transformer is needed?
Preamp for Tube/Mosfet amp
Part list:
R1,R2-12k 2W
R3,R4-220R
R5,R6-680R
R7,R8-100R
R9,R10,R13-1M
R11,R12-3M9
R14,R15-10k
R16,R17-1k
R18,R19-10R
R20-680k
R21-470R
C1,C2,C3,C4-1uF400V MKP
C5,C6,C8-22uF/350V
C7-47uF/16V
C9,C10,C11,C12-47uF/350V
C13,C14-1000uF/16V
C15-47nF/100V MKS
C16-220nF/150V MKS
C17-100nF/63V MKS
D1,D2-ZF10V
D3,D4,D5-1N4148
D6,D7,D8,D9,D10,D11,D12,D13,D14-1N4007
V1-ECC88
Q1,Q2-BC546
Q3-IRF830
IC1-NE555
IC2-7805
LD1-RED
LD2-GREEN
RE1-5V2X1A
AC1-120VAC 100mA
AC2-9VAC 1A
i haven´t built it yet,but viktor has heard some nice impressions. :sax:
Part list:
R1,R2-12k 2W
R3,R4-220R
R5,R6-680R
R7,R8-100R
R9,R10,R13-1M
R11,R12-3M9
R14,R15-10k
R16,R17-1k
R18,R19-10R
R20-680k
R21-470R
C5,C6,C8-22uF/350V
C7-47uF/16V
C13,C14-1000uF/16V
C15-47nF/100V MKS
C16-220nF/150V MKS
C17-100nF/63V MKS
D1,D2-ZF10V
D3,D4,D5-1N4148
V1-ECC88
Q1,Q2-BC546
Q3-IRF830
IC1-NE555
IC2-7805
LD1-RED
LD2-GREEN
RE1-5V2X1A
AC1-120VAC 100mA
AC2-9VAC 1A
okay, thanks, I'd love to build a tube preamp, I try to build it slowly.
i finish my ml3 and xl2 it sound so good.. great bass mid and treble i can adjust without affecting its other
Hi Apex, this is a great thread indeed.
I have been reading since your first post but I am unable to find a stereo 3 band equalizer module on a single pcb using dual potentiometer. ( I might have missed that, I am afraid).
Could you please kindly post a 3 band equalizer circuit and a compact single PCB Layout specially meant for Hi-Fi home stereo ( using NE5532 or TLO72, dual power supply, dual potentiometers( 100K or 47 K) , etc)?
Please consider this earnest request.
Thank you so much for this awesome thread.
