Mic, Line, EQ... Preamps
by schematic Apex MX1, I use to stereo to mono preamp.
I combine it with the B500. results signal sounded perfect and does not eliminate the original frequency. thanks Mile. sorry my bad english.
sir mile, should I replace the R input 22k? for better sound?
My First Tube Amp
I've tried it with the specifications provided by APEX, but I have a problem on Mute / Operate Relay does not work and the red indicator lights up, if you can help me APEX? I question my view on the schematic point 4 da 5 connected goto +6.3 V and point 9 to the ground, but the PCB layout I created only 4 only connect dots and point 5 is not connected to any section. please help Mr. Mile. sorry my bad language.
regards
Damanhuri
APEX FAN CONTROL
Just want to share for all diy freind may need this APEX fan control.
Regards,
PRE-AMPLIFIER-* FJROMERO
The creator of this preamplifier is known in this forum:
FJROMERO
In this thread I will post preamps, EQ, active x-overs, VU...
ML3 is Mic/Line XLR preamp with three band EQ +/-20dB
PCB size 100x40mm
Share this preamp:
Design of Sr: TUPOLEV.
Redesign: YIROSHI
also can be found on the website of video jukebox.
stereo preamplifier
VIDEO ROCKOLA
pdf format
Dear Sergiods,
I really don't know how to thank you for this preamp post. Thanks a ton, really!!
Another very urgent and earnest request.
Could you kindly post a "ready to build" 5 band/ 6 band equalizer circuit with TLO74 etc. and a PCB layout for that?
FJROMERO
Share this preamp:
Redesign: YIROSHI
stereo preamplifier
VIDEO ROCKOLA
pdf format
Hope I am not threadjacking. I apologize to Apex and all if I've done that inadvertently.
Hi Sergiods,
I've started this test project as a Practice (with some old components from my inventory) before I attempt to make 2 ML3 Pcbs with Apex's great design which has a better 3 band equalizer imho. I just was interested in the dual version of your post. :)
This project ( photo in the attachment ) will be my temporary solution until I make 2 ML3 tone controls. :)
FJROMERO
Share this preamp:
Redesign: YIROSHI
stereo preamplifier
VIDEO ROCKOLA
pdf format
I made this and found a weird problem. Apparently the sound is very good. The karaoke function is very good too.
But after some 5 minutes after power up, the sound becomes distorted or even stops when the bass control is at maximum position. And a sparking noise is coming.
When I reduce Bass a little everything becomes normal again.
There is no overloading of the source. No unwanted noise. The voltages are normal too. I am using +-15V dual power supply.
What can be the problem?
I followed the construyasuvideorockola.com and the pdf file in the download section but main problem is I don't know Spanish. So no help for me there for this trouble shooting. And here I didn't want to start another thread for this problem.
If anyone faced similar problem with this and resolved it, kindly help me out.
Thank you in advance.
