Ultra Simple Class D
hi guys. the hi power version in bridge mode. i will upload artwork later ;) ;)
  • Class D 200 Wrms with 2 mosfet bridged schematic.pdf
hi all i made bridged version and tested it but . when i pushed it hard with a 6ohm load that is a 18inch woofer the amp failed after 2 minitues. .i think my tracks for pcb were small the ones feeding the output fets. also
>>> btw the circled components were heating above normal.
here are the photos
  • Class D 200 Wrms with 2 mosfet  bridged schematic heating components_1_1.jpg
sweetperfume:
No,the opposite is correct:D.
A speaker is a non resistive load, in fact it is a nonliniar inductive/capacitive/resistive system depending on its configuration(single or multiple in cabinet and with or without filters).
stewin:
Power resistors with their resistance smaller than rated impedance, example: for 4 ohm impedance use 3 or even better 2.5 ohm low inductance resistors or resistor network
hi all just found this schema by detex audio . it seems simple . what makes it 100watts and not 200 watts?
:D :D :D
  • detex 100wts amp.zip
  • NegativePCB.pdf
