Studio Reference Amplifier
Miku, I take note on that.
Carlos MkIII is good too compared to SR200 it has a punchy bass while SR200 is like you're having a Subwoofer.
And yes the speaker has low power handling but I'm not blasting it out, yeah you know play music just to relax :drink::).
That´s cool! :) I am glad that you are satisfied with that amplifier,my plan is to make SR200 too-i have allready done some prepairing. That amplifier is something that is "must have" ! :)
time to cool it off.
Ive Etched and started to built up the New pcb from Alex_MM SR200 Ver3.1
I have some questions,
1.) I see Mr Alex included 2x100nf decoupling into the 'signal' ground from the 15V rails,
I don't see this on the Original Circuit Diagram, just wanted to check if this is best to add ot leave out ?
2.) I need the voltage rating of two capacitors,
C9 ? I'm guessing it should be a high voltage ?
C7 ? I'm guessing that a low voltage would do,
But Id prefer to know what Voltage rating is correct,
In attached picture is my litttle amp progressing and the SR200 v3.1.
Thanks so much
