update: I found the caulprit, it's my mistake anyway. An ungrounded heatsink in KSE350 which is act like an antenna, now it fixed properly.
Can you post picture close up to all component...
Hi Wil,
Here you go.
Other channel is rock solid except this one, I might change all output tranny.
Thanks,
Junie
Hi Jun,
Opss.. sad to hear that bro, i suggest to double check and confirm first before replacing don't waste.. they aren't cheap tranies.
Did you use any replacement? I suggest to do actual test vs. schematic before solder specially replacement tranies.
FYI only, in Middle East i encounter lots of tranies have different pin orrientation as per original data sheet so better to do actual test before solder.
Wiljj78
Yes Wil,
Will do that, but surely oscillation is happening, i can say that because if i touch the heatsink of KSE350 the light bulb is glowing a bit, soething is wrong in that section. Will tackle this issue later, I will keep you posted.
Junie
Hi June,
I hope you insulate your rear metal case of both Q7&Q8 MJE340 or KSE350 against heatsink, sometime shorted may occur on collector to heatsink which it shouldn't be.
these type of transistors doesn't have a metal tab behind, it's all encapsulated in plastic package but something is picking up a frequency from that area i reckon.
Connect 5-10pF from colector Q9 (MJE350) to base Q2 (BC560) for compensation.
Hello Amptech,
In the final PCB Alex include it (enclosed in red), please see below photo.
Actually my approach on finding the fault is from OP backward but I noticed that whenever I touch components in the input stage the buzzing sound is there and the Light bulb is glowing happily, double checked the schematic and found the cap(100pF) is missing.
Junie
Junie
Ok here's what i found, in the schematic below the 100pF(enclosed in red) is not included in Alex's PCB version 3.1.
With the inclusion in my build it removes that unwanted oscillation, noticed how did i solder in the back of the PCB.
Congrats....and thanks for sharing.
Which version is working fine??
DC protector for B500
Mr. mile DC surge protector is whether it can be used for the B500?
Regard
Schematic of Speaker Terminal.
Regard
Regard
Regard
- Studio Reference Amplifier
