Switchable Hi-Z input impedance, how ?
Ex-Moderator R.I.P.
Joined 2005
found RCA tone control manual
and a Crowhurst article
looks like even I can do that :D
btw, consider its a 2channel/stereo
using one channel for bass, and one channel for mid/top
enables the two channels to be configured differently
like using the trick with a small bypass cap on cathode resistor, to achieve a little more high frequency gain
and having seperate attenuator for each channel further enhances sound balance control
Ex-Moderator R.I.P.
Joined 2005
trying to draw curcuit, with EQ
not sure why the cathodes are bootstrapped
but seen that elsewhere
hmm, maybe only output tube should be bootstrapped
Ex-Moderator R.I.P.
Joined 2005
ah, ok
by bootstrapping, the input/gain tube would achieve a bit more gain
guitar amp builders say it gives more 'grunt'
well, no real need for that here
bootstrapping the cathode output tube gives higher impedance load
and that might be of advantage, considering the EQ curcuit
well, I dont know this, but it seems logical
hope its beginning to look better :p
Ex-Moderator R.I.P.
Joined 2005
and this is the way I plan to use it
seems like I will have to do some cuts for soldering directly to the ground plane, or else it takes too much heat
hmm, solder pads appears to be a bit big for some smaller components like multiturn pots with smaller legs
might have to use bigger pots
or try to build a smaller tool :h_ache:
well, I might take the challenge :D
Ex-Moderator R.I.P.
Joined 2005
not long ago I found an old B&O receiver
it gave me a nice trafo
but I also took the frontplate with me
I felt stupid, but just thought it looked nice, and might be of use, somehow
hacking off the right piece, and voila :)
