F5 power amplifier
only tru on 230v it supply. however we also have 400v tn, and it have a dedicated neutral. it is possible to get 230v from that supply.
you should really read up some about the topic :)
btw the plug is called schuco...
thats 3phase that don't exist in any homes you can have it in your garage.
there is also a 1 phase. thats normaly used on caravans and such.
NP has said the max he would run the power mosfets is 50W. Calculate potential max bias depending on your rail voltage.
Yes prety right for large ones TO247 TO3p 40 W for litle ones TO220
I have been running pairs of FQP19N20 and FQA12P20 at 32 V 2.6 A since last August on 300 X 400 X 86 sinks (190 W) soon I am going to do balanced on same sinks and may need litle fans to help a bit.
And Papa uses Mica and goop with big washer so there may be same head room if one uses Kerafoll and prety uge clamp bar and massive screws :D
Bksabath wins todays FAB award
what the F...k is a FAB do I get prize for "to dumb to get that":D
and as one mention big heat sinks...
not big enough for balanced!:(
Scary about electrical installations
In UK we are doing a bit better than rest
1)electricians are liable of prossecution for man slaugter if negligent
2)One is not electrician till he read the IEE and pass test (the book itself cost only £70)
3)if is not in the book is alowed (old 16th edition wuld not alowd soket in batroom but one could fit soket inside kitchen sink as word kitchen sink is not in the book.
This all changes in 17th edition mainly due to RCBO
if you do not understand this learn it or get professional to do job for you.
Then if accident happens and litle ones get it, you can sue cowboy that fitted fing instead of spending rest of your life feeling guilty.
Do you need example?
Why UK apliances must have plug fitted?
This came up since Selfridges sold washing machine to Mum.
Washing machine did not have plug and mum decided to fit that (how complicated is that
fitting 3 wires compared to caring for baby)
So Mum fit plug start washing and all is fine till Housband came home to find Mum and Baby dead.
All was fine till washing ended and Mum holding Baby went to open washing machine door.
If you get abowe then ....
Nothing beter than one running its own circuit for Hi Fi sokets with suplementary earth spike in to ground if executed by the book (wach out for Cows if you liwe in the country)
Hi guys!
When we see "Heppy End" of this project?
How far we go, or what the rule is true universe is infinite?!
cheers!:cheers: :eek::crazy:!!
No universe if quite finite as it is still expanding and will eventualy get almost nearly there to be infinite but not quite so as it will eventualy cotract.
And yes universe is infinite for us as we don't see baby Good plaiing trough the soap.
Pick one you like the best no big difference in between
