Fairchild interest alternatives
F5T 19n20C replacement
  • FQA19n20L
    Votes: 0 0.0%
  • FQA12n25C
    Votes: 10 83.3%
  • FQA32N20C
    Votes: 0 0.0%
  • FQA28N15
    Votes: 0 0.0%
  • FQP TO220
    Votes: 2 16.7%
  • Total voters
    12
  • Poll closed .
I am going to open this up to discuss alternatives to the N channel parts spec'd in the the F5T. The P cahnnel parts can still be had, but the 19n20C are pretty much a no go. There are plenty out there, but i have found a 100% fake rate. No one has original boxes, and without it, your chances are sketchy at best. There are over 50,000 of these things floatig around in Asia, some being made in 10' and later. That should tell you all you need to know. There are two other 19n20 parts, the standard version, and the "l" version, both with increasing Yfs and Ciss. Of these two, the standard part is a better match on paper, the 19n20"L" part has double the Yfs(transconductance) and double the Ciss. THis is still available. Another EOL part that i think matches better on paper is the 12n25C. It is EOL, but still available, the question being one of sufficient quantity. OTher than these parts, the only new parts i found that look close are the FQA32N20C and FQA28N15. Other than these, we have the option of the smaller die package FQP of the original parts. I am going to start a poll so that we can vote. I'll look at the results and we will go from there. Please let anyone on the orginal GB know.
Sometimes I have that feeling of mine, Papa makes his amplifiers from unattainable components, because it is not possible to make a copy from these so.
This was a malicious comment now.
Let somebody correct me if this is not so.
I think that may be a stretch. You could have gotten these components easily when the F4 was released. One ofthe early builders, Cviller, made it well known these were the components used by Nelson.
As mentioned above, this was just a malicious comment.
You know, I am like that than Gargamel.
Ugly old small bald evil.
I was thinking about these, but not good:
  • Fairchild_IRFP240.pdf
  • Fairchild_IRFP9240.pdf
I agree that it is not too big of a deal. There are alternatives, including Fairchild options mentioned. I was trying to keep the P part which is what Nelson highlighted. P3 ishuge help any way you go. I even tried fakes in amp. Sounded normal, slight oscillation problem though. I am going to get all the alternatives of FQA parts and compare them to good "c" part. Should have some real info to look at.
I am almost 100% sure that i have secured what i believe to be the best alternative to the 19n20C. I have one more lead on the original, but if it doesn't pan out, I would suggest FQA16n25C. I will provide links to both datasheets and I believe you will see that they are almost identical in performance.
FQA19n20c link from digikey
MOSFET N-CH 200V 21.8A TO-3P - FQA19N20C
FQA16n25c
MOSFET N-CH 250V 17.8A TO-3P - FQA16N25C
This should allow you to get datasheet direct from Digikey
I can get FaArichild orginal FQA16n25C parts in sealed boxes. I have some samples on the way and will provide a comparison between it and the orginal 19n20c part. If all looks good, then i will put it into an F5T and try to get some distortion numbers to compare to the article. I also will try to contact all GB members and inform them of what is happening.
Thanks buzzforb. I agree, the 16N25C is an excellent replacement for the 19N20C. I haven't had time to do the research on Charles Hansen's suggestion of basically selecting a higher voltage complement to get the Transcunductance down to match the P part. I use a 150V part sometimes that is 20S! I think we should look for 400V N parts?
:Pawprint:
