The simplistic Salas low voltage shunt regulator
diyAudio Chief Moderator
Joined 2002
i also remember having read multiple times that it is desirable to match parallel output devices in the output stage of amps but i m not sure why...could you (or someone else) care to explain? i understand that heat load will be shared even but that is it...
also, i understand that having the lowest possible bias through the bjt (see pic) gives lower output impedance, so i m wondering what obstacles do you encounter when lowering to much the bias. is there a sweet spot? in the pic it is around 4mA depending on the mosfet.
To avoid current hogging that leads to a catastrophic sequence.
The output impedance will be a function of the error amp's open loop gain and the current follower's transcoductance. R6 gets to be a CCS and the follower's bias gets to be spared higher to trigger more Gfs if we are after decreasing Zo.
you mean that we dont want to be in the bottom portion of the graph in the attachment, where linearity is not so good?
yes i just remembered that a jfet had replaced the resistor in the later versions.how about 2 jfets cascoded to further improve Zo?would you advise against it or should i let myself go?
P.S.: just tell me if i get annoying with my questions and i ll get back to my books :)
Joined 2002
We don't want one in a group to draw more current than the others, as it gets hotter it draws even more, vicious circle until it fails and kills some more. So we match them and/or we give them little source resistors like in amps.
To make a cascode is not recommended when you will only have 3.3V and in there you will have to fit one vbe and two Vgs drops. Use a BF245A, its enough low pinch off and low capacitance Jfet good for VHF/UHF amps even.
yes indeed, fitting a cascode within around 2.5V 2sj313 Vgs looks pretty lame. forgot about that :).
thanks for showing me bf245a looks better than 2sk170. looks also like it would require very low current to be effective. maybe something like the less available 2sk369 would be a better fit(although capacitance is higher...)?
Joined 2002
Look how the capacitances enlarge the lower the Vds. Best is the 3rd one for low output voltages for instance. The middle depletion one is out of the question in any case with 0.1S gfs and no sinking ability.
Is it possible to get -3.5V out without modifying the second picture in post 3200?
no. because of the mosfet Vgs. maybe you could get -4V or so. But if you choose a lower Vgs mosfet, maybe you could, just like i m trying to do with the V1.1. i dont know anyone who has tried yet. (the reg you are talking about is attached)
yes the third one could be nice at high current, albeit being t0-251.
the little depletion one is rated 160 mA max continuous Id. But looking at the curves, i thought that a characteristic 0.4S and around 5pF Crss at 3.3V could be interesting to test, if only to know what benefit low capacitance can bring. Or maybe this is a bad idea altogether...? Moreover, a shunt device battle Bc560c vs little mosfet could be cool :)
for comparison, irf610 has around 50pF Crss at 5V and 0.4S at around 150mA and a better 0.8S at 500mA.
check the voltage drop across the CCS resistor.
That suffers first when mains voltage drops.
If the CCS starts to lose Vdrop then it is no longer a CCS and the attributes of the CCS are lost.
The Shunt part attempts to compensate for the lost CCS current flow by reducing it's own bypass current in trying to maintain output voltage. The reduced current shunt is now not operating at optimum.
Checking output voltage vs input voltage is not the correct way to determine if the CCS + Shunt has sufficient supply voltage.
Check the CCS resistor voltage. It should be substantially constant over the full range of mains supply voltage.
