Hifimediy T4 board
I meant the black cap which is connected parallel to the + and - poles on you big blue capisitor.
Oh, that one. It is a polypropylene bypass capacitor, it adds no voltage along with the other smaller one. I've seen it done by many, but how it affects sound, I don't know. Its effect is not as clear to me as bypassing the input capacitors, in which case I did A/B the sound.
Okay forgive me for being a noob, but I've got a question. While I'm waiting for my replacement T4 I thought to construct a simple rectifier so I could connect to DC instead of AC. This by using a 25A 50V rectifier and a couple of 22000uF 100V Philips caps I have. So I connected my 33V downsized toroid to the rectifier and attached three of the caps to the poles of the rectifier. Then I measured the voltage being 90V !!! Unloaded. Is this correct or am I forgetting something? Yes yes I'm a beginner with small steps in the wonderful world of DIY amps...
Make sure you are measuring AC with AC Volts setting and DC with DC volts setting on the voltimeter and at the right place on the rectifier, AC where you see ~ and DC for + -
Perhaps...
Also, 33 v AC * 1.414 = 46.662 VDC, add maybe 1 volt for the caps if necessary, you should be about 47-48 volts rectified DC.
I am finally going to order a T4 amp to test with our high efficiency Klipsch speakers. If it works out okay I'll order 3 more to allow Active EQ on the 3 fronts in our 5.1 system.
Have a couple of questions.
1. There appears to be some kind of 'Molex' connector for input on the amp. Do they ship a matching connector and or some kind of plug/cable with the amp? I can't find any info on their website.
2. The amp doesn't have volume controls and I would like to add a volume control on each input (ganged).
A. Any idea what resistance pot to use? I'm driving the amps directly from an Asus Essence soundcard in our HTPC.
B. Might this addition have negative affects on the sound quality?
Thanks for any assistance.
Rod
Can you post a picture of how you got things wire up and where you are measuring?
Well I was about to take the picture but I measured on a couple of places and am confused now.
34VAC > ~ input rectifier side > + rectifier pole > + pole capacitors
0VAC(not used)
34VAC > ~ input rectifier side > - rectifier pole > - pole capacitors
So at the rectifier poles I measure 54 volts and at the last capacitor pole I measure about 90 volts.
0VAC(not used)
I think you have the secondary (output wires) wires of the transformer hooked up wrong.
If you have dual secondaries (four wires), then the "0" wires should be on one ~ pole and the "34" on the other ~.
If you have one secondary (three wires) winding with a center tap "0", then this center tap must be on one ~ pole and the other 2 wires on the other ~ pole.
If NOT, then when you measure you would be capturing the additive voltage 34 + 0 + 34 = 68 VAC * 1.414 (rectification) = 96 + VDC.
But before you go blowing anything up, let someone confirm the above information.
I have five wires. 2 times 34 VAC, 2 times 18 VAC and one 0 VAC.
So I have to wire the two 34 VAC together on one ~ pole and the 0 VAC to the other one?
This may help, I use the Avel transformers and connect the secondaries together. Look at the top config in this photo, it may make it clear. It would help if you know the wiring configuration of your transformer.
Anyhow, don't hook up anything but the rectifier to it and get the correct voltage. This way you will not blow anything up.
