Ordered the PCB and the first component today.
I like the sound from my Marantz CD-60, even if it's only partially modded, so I wanted that sound for my PC too.
This build will take some time as I'll gather parts as I can afford them..
DAC PCB
SAA7220P/B
and finally
DAC PCB
SAA7220P/B
and finally
This is the Analog Metrics PCB? If so it has a design flaw in that the replay clock (an XTAL OSC module) isn't locked to the SPDIF input resulting in skipped or duplicated samples every so often. Worth knowing that I feel before you begin to troubleshoot any clicks or glitches you encounter
It's this one
I've heard of people being very pleased with this, although that's been the complete kit.
Yep, that's the one. The people who are pleased with it can't have noticed the skipping or duplication of samples.
Is this something that can be fixed?
Not simply, because it would need something of a major redesign in regards to the clocking. Best have a listen for yourself and if you don't notice the defect then it won't matter.
Will do
Thanks for pointing it out though!
This will supply the I2S signal until I can afford better.
I'm hoping the coaxial out provides I2S....
Genuine IC?
You haven't read his negative feedback then ?
No, and I haven't ordered it, which obviously is a good thing. Thanks
Yes it is.
There are some things that are easy to research.
With Asian suppliers the first place to go is the ' Negative Feedback ' section where all your questions are answered.
I'll keep that in mind
I just checked ' Polida ' and his feedback then found 11 references to ' FAKE '
just on the first page.
There'll be more.
It's very hard to spot these things sometimes and I too have fallen for it.
I remember buying some Black Gates a few years back from one of these Asian cheats and when they arrived I just knew I'd been done.
On reflection they were just too cheap but back then I was just over eager.
Now if I see something interesting I go to the negative feedback pages - it tells you everything about the supplier and can be very funny too if you just need to have a laugh
There'll be more.
There'll be more.
I actually have a TDA1541A in my watch list that's about twice the price from a seller with no negative feedback about fakes, actually 99,8% pos feedback.
Just thought I'd check the cheaper one out.
How about the Valab 1ppm 11.2896 TCXO for this board?
It's rather cheap, any better ones that are about that price?
Was looking around for a better USB to coax than the one I've got...
Is the Teralink - X2 Native 24/96 a good option or are there better ones for about that price?
I've got some time to look for the best options as I'll gather parts bit by bit as I can afford to.
- Digital Line Level
- DAC build TDA1541A/SAA7220P/B *will take som time*
