MPP
Joined 2006
Cool. I like leds and this way we avoid zener noise in the opamp psu but I would avoid blue ones.
I experimented a lot with leds on series regs and the lower noise ones are yellow / orange. mine have 1.9Vdrop at 20mA so I will use four for each rail.
Here's the updated circuit, with LED reduced supply for the Op-amp..
Joined 2005
you bet.....
here are the schematics of the preamp and regulators, please take a look if everything is correctly captured. I will start floorplanning with these versions now. I believe the consensus was that the transformer, rectifier and bulk caps are supposed to be in an external enclosure, correct?
enjoy.....
  • ParadiseAmp r1 20 12 2011.pdf
  • ParadiseReg r1 20 12 2011.pdf
you bet.....
enjoy.....
In the power supply
R105/205 originaly 500 Ohm kan be 470 Ohm
R106/206 should be 2K or 2K5 trimmers to adjust the output voltage
Otherwise it seems o.k.
Frans.
you bet.....
enjoy.....
Also change the BC550/560 to BC327/337, that is more in line with preamp. Just for fun :)
On first sight the schematics look right.
I will print them out and look more careful later.
Please make space for 4 Leds in series before the servo, just in case somebody is not comfortable with the blue Leds. For some servo ICs we have to drop to plus-minus 15V.
For example the AD825 can stand only plus-minus 15V. Some say it has magical properties as a servo because it has an open loop bandwidth of 10kHz. With 12nV/qHz it is a bit noisy though but that does not play a big role here.
