As seen, neither averaging 1x, nor shortening the FFT window shown anything new, only loss of FFT resolution.
Seeing as you replied that you were seeking to reveal myths and speculation with your measurements, it comes as no surprise that's what you found. Now, if your heart had been in it to find something real...
I want to thank Thorsten and others for this enlightnining discussion on digital, and WHY it sounds that way. While I have chosen in my limited lifetime to specialize in analog design, it is both interesting and necessary to find out what has both improved and what has been 'denied' as being wrong with digital. The debate between Thorsten and PMA being extra enlightening to me. This debate has been with us for decades, and I am continuously put in a position to monitor (with relatively fresh ears) each year, the state of the art in digital recording and playback, including SACD. Sometimes it is pretty good, but I will stick to analog, myself.
Very old systems with analog A/D anti-alias input filters? (I guess from ... "decades ago"... statement)
What is wrong with an analog anti-alias (i.e. Low Pass) A/D input filter?
George
Any relevance (even remote) with the components/construction vibration “acoustic signature” topic?
Technology for obtaining electromagnetic energy from sound waves - DigInfo TV - Tech News Videos From Japan | The latest technology, products, gadgets and scientific research direct from Tokyo
George
George
Very little has been said as to why anything sounds the way it does. SY played some live music recordings through a $29 USB to SPDIF dongle (not even in an enclosure) for me last night. Why there is still a business in $12,000 DAC's, etc. is beyond me.
George
It is almost impossible to make steep analog filter (to prevent aliases) with low ripple of amplitude response and same time with suitable phase response in the passband. First A/Ds had low sampling frequency (no oversampling, no sigma-delta 1 bit) and thus needed steep anti-alias filters. Huge box with poor response.
http://forum.blu-ray.com/audio-theo...standing-d-analog-digital-conversion-pcm.html
Pavel,
With respect, I suspect you do not know the story of the drunk guy, the police officer and the car keys...
I understand you are looking where the light is good, but the car keys are over there, where things are quite dark and murky.
Lest you you use a method that is appropriate to look for these "mythical" problems, you will not be able to measure them any better than for example PIM and TIM using standard THD+N.
But as I percieve that you very much DO NOT want to measure them, please do not change your measurement methods, for if you do, you may dislike the results, I sure do dislike them...
Ciao T
Massive averaging shows components buried in noise (without averaging). As seen, neither averaging 1x, nor shortening the FFT window shown anything new, only loss of FFT resolution.
Ciao T
John,
I come form a hardcore analogue background (Industrial/Military process control in the 80's in eastern europe), but even then mixed signal started to show up. I got into Audio almost by accident (basically being blacklisted by the communists government for political reasons) even though my early forrays into electronics in my pre-teens where very much music/audio related.
For a long time you could have coloured me as "militant vinyly", to the point of complete dismissal of CD as Amusical. However, it bugged me and I kept pecking away at thing.
In reality I am much better at analogue and RF design than at digital design...
Hey, hold it, outside some conceptual prisons even digital signals are actually analogue and RF...
Oh well...
Ciao T
Oh well...
Ciao T
Again, an example of your PIM measurement would help more than quite empty sentences
Please distinguish between THD+N (number, or plot of number vs. frequency) and FFT spectral analysis. FFT will show you jitter, e.g.
I am looking forward your PIM measurements.
TIM is very easy to measure, but no properly designed circuit has any measurable TIM. Just IM. TIM is a story of the past, .... "decades ago"...
Scott,
A lot has been said, but arguably, it requires the ability to integrate this information with prior information, rather than outright rejection.
Well, given that most current Speakers do not give good sound when connected directly to a digital SPDIF signal the reason may be by far less beyond you than you think.
Of course, such truth are neither convenient nor orthodox, so it may be wiser to take the road of the ostrich, that noblest of all fowl, famous for it's way most effectvive and expedient way of dealing with things out of the ordinary (sticking it's head into the sand)....
Ciao T
Ciao T
Thanks PMA
So, the emphasis on your ref post (#16733) was on the "very old" (implying low sampling rates of the time) and not on the "analog". Today with the use of higher sampling rates, analog filter is a good choise
From your reference link above:
George
Unfortunately, when you use an analog anti-aliasing filter, the steeper the slope, the more distortion will be present near the cutoff frequency. It is better to use a shallower filter. This would imply that it is better to increase the sampling rate such as 96 kHz (with a half frequency of 48 kHz) to allow for a higher Nyquist frequency so that the anti-aliasing filter's slope can be shallower and thus result in less distortion.
The higher sampling rates allow for shallower anti-aliasing filters and thus less distortion. Generally speaking, the higher the sampling rate, the higher the allowable cutoff frequency, the shallower the anti-alising filters, the safer the filter, less distortion, and the higher the frequency range. Consequently, none of the problems that exist when filtering a steep slope are encountered. And, since these filters no longer have steep slopes, they do not further distort the sound with phase shift or group delay.
George
Pavel,
As English is not your first (or even second) language, it may have escaped your notice that I used THD & N vs PIM/TIM as an analogy to point out how your FFT's where fundamentally incapable of showing things that are random or at least semi-random in nature (that is, the FFT will not resolve them to a single spectral line), that happen dynamically and affect only a single sample, any more than a 1KHz THD & N will reveal the presence of TIM and/or PIM.
For example, using 8K samples will suppress such a "fuzzy distortion" by around 40dB!
However, as I said, you have your deep seated prejudices and ayou are not interested in what really happens, so I see little point in debate.
Please continue as you do and pay no attention to the man behind the curtain...
Ciao T
Ciao T
Yet Peter Baxandall declared this particular kind of boxes to be "essentially sonically transparent" (that is, he was unable to distinguish them on insertion).
I have my doubt that he (who has sadly or perhaps thankfully left this plane of eXistenZ) would feel similar about a chain made with current day "24 Bit" ADC's and DAC's using anywhere between several percent to nearly 100% "fuzzy distortion" as fundamental operating principle...
Ciao T
It was both "very old" and "analog". Low sampling frequency of first recording ADCs resulted in necessity of very steep analog filters, huge boxes with poor phase response, probably sometimes even poor amplitude response.
Ciao T
Gee, Scott, you replied without answering my question, and then dropped a name that I don't know, either. Who is this Bob Adam?Funny, I had to google DSD. I have not searched but I find it hard to believe that the different digital systems have not been compared on first principles of information theory at least somewhere.
And as I said before it does bother me just like it bothers Thorsten that the massive averaging to make nice pictures (maybe) does not address the instantaneous performance. Luckily I can walk into Bob Adam's office and have him try to explain.
If you want explanations, browse the AES library for John Vanderkooy's papers. But I think you're right to be concerned about the impulse response of SACD, if that's what you mean by instantaneous performance.
DSD is not so hard to make sense of via Google. Try DA, though. I have no idea what you guys are talking about, and Google really can't help. See Wikipedia for a funny list of possibilities, none of which are audio related.
DA = Dielectric Absorbtion - wikipeda has an introduction under capacitors...
Ciao T
Ciao T
the full complex Fourier Transform of a time series is an exact Dual == contains all of the information from the time series - including the variation of each and every sample from noise, distortion, from any source
whether it makes certain phenomena more or less visible to the human eye/brain is the whole point of using both views: time and frequency domain
if the FFT isn't the "best" tool that doesn't mean you can get off with hand waving assertions - describe the signal, noise, distortion properties - in the time domain if that is easier
but without a definite technical description of the problem(s), measurable consequences you are simply not participating in a technical debate - just baiting
Thanks. Rather than complain that Wikipedia had no link from "DA" to the appropriate sections under Capacitor and Permittivity, I just added one. Maybe the next guy will not have to interrupt the conversation...DA = Dielectric Absorbtion - wikipeda has an introduction under capacitors...
You need to consider the case of a discrete time, discrete level Fourier transform, not the mathematical model. The limits of sampling rate and accuracy will affect your results.
Many here have found that 16 bit recordings at 44,100 Hz are not as good as 24 bits at 192,000 hz. for reasons open to debate. So if you want to make a measurement of the difference, you will require a minimum of 25 bits at 384,000 hz. for your analysis. (Ignoring such issues as clock jitter, noise and other sample errors.) To be safe you might want to go to 26 bits at 768,000 Hz. But of course the equipment to do that doesn't exist.
- Member Areas
- The Lounge
