Because the question resurfaced: This GB and Ollie's PCB GroupBuy are SEPARATE.
We are not the same person, have never worked together and we don't know each other from any previous events or cooperation.
There is no problem between us either, we are simply two separate people doing separate GBs.
You can also not order his PCBs through me, please contact him via his thread for any PCB orders.
And if you ask him nicely, he might ship your PCB(s) to me and I will forward them with an order you have placed with me.
That way shipping can be combined and all your stuff arrives at the same time.
This also means you have to register for this GB for the kits with ME.
Ollie can not put you in a spreadsheet that is on my iPad...
I hope that clears things up a little.
Jokener
Jokener
just for the record: I tried to post this last night but due to I don't know what it did not show up. I was completely aware that the PCB GB and the parts kits GB were two seperate things. Again sorry for any confusion that was caused by this and my hurried payment.
here my order, as you are already aware of
2 kits
2 silver enclosures
1 power plug
2 kits
2 silver enclosures
1 power plug
No I didn't know that.. thanks for the warning...Just to confirm, you are aware of the 20€ penalty for the green color?
(Green is shipped from China -> Customs, extra handling, ...)
Standard colors available for shipping from Germany are: Black, Silver, Red, Blue.
2 x Blue please (instead of the green)If you like, I can switch your cases to a standard color...
Not a problem, I can sort that myself.Also, the AC adapter has a euro-plug on the primary side.
-> UK buyers need to cut the cord and replace the plug. Not difficult, but you need the plug.
Thanks for the info.
Phil.
Because I was asked a couple of times:
Yes, there is a difference between the sum of Parts, Extras, Shipping and what is shown as 'total'.
If you download the 'numbers' or 'excel' files, you can see the syntax behind the PDF.
I have added a 5% cushion to cover the PayPal fees.
(PayPal fees are between 3% and 5,4%, depending on currency and location...)
Jokener
Jokener
order
-my order below
-and i'd like to pay by bank transfer, can i get your bankaccountdata?
-i come form the Netherlands
1x kit
1x transformer
1x NJ3FD-V Vertical Panel Mount 1/4" 3 Conductor Phone Jack
1x NYS367-2 Female Panel Mount RCA Jack Gold Red Insulator
1x NYS367-9 Female Panel Mount RCA Jack Gold White Insulator
1x B3-080BK Extruded Aluminum Enclosure 100x80x45mm
1x EC3-BK Soft End Caps for B3-080 Enclosure
1x 577-1810-5F De-Soldering Wick Braid 0.075 in wide (#3) with flux
-my order below
1x kit
1x transformer
@architect:
I have added your order as you have stated, but I'd like to clarify:
The "extras" may look very expensive, but the case and protective feet you have chosen are import goods.
I have contacted Farnell for clarification, but I think they will charge the 20€ import fee per different item (so 20€ import fee, no matter if 1 or 10 of your import cases).
I will update the prices if they get back to me with the information that it is only 20€ per order...
@Zoid: noted.
Everything should be up to date now.
@Zoid: noted.
- Group Buys
- O2 amp parts GB, EU
