PCB for cascoded IXYS CCS (tube)
Hi all
I can only check randomly my mails (at the moment on a beach from mexican caribe ... ole'!) but I believe I received all the missing payments. I'll update the balance sheet and donate to save the children next week.
Let me know how the PCBs turn out once populated!!!
Gianluca
Ciao,
Enjoy the well deserved break! Tried the CCS configuration over the weekend on a breadboarded 26 preamp and worked just dandy!
Excellent work
Ale
One of my pcb's partially populated.
attachment.php
It has been earmarked to replace two chokes. I can't place the chokes far enough from the power transformer to prevent hum. So I'm going to try this in my DAC. 6N6P at around 14,5mA per side. So I used the IXYS 100d top spot and dn2540n3 in bottom spot. Not sure if I'll need heatsinks.
Also a question I have. Should the external cap pads be jumpered with a wire if just using it as a CCS?
glad the pcbs are working.
here it is the final balance, apparently i miscalculated your total mogliaa in my old PM. the remaining money will be donated to save the children as said (25$ out of the 88$ actually were donated a while ago)
Luca,
thank you!
So ccs all around will be ! Choke for that use ( 80 -150 H) are expensive.
What resistor value do you use?
I have some ixys from your last GB, will use for sure.
Yours too seems impressive! How it sounds?
Mine for now is only on paper...have some components, need all iron.
Ciao
Anto
That amp was a 100TH CCS loaded driving a even bigger 304TL ... dismantled after a week or so, it was way too hot. Your amp will need a ton of transformers ... I assume you are aware you need DC on filaments (current sources there too). Enjoy!
The dropping R before the CCS can be anything > 1k
