Pictures of your diy Pass amplifier
Official Court Jester
Joined 2003
can we count this one in this thread ?
http://www.diyaudio.com/forums/pass-labs/174674-papas-koan-papas-surprise.html#post2320759
:rofl:
Do the central heat sinks dissipate enough heat mounted that way?
Yes, I use raised power supplies (32V) and increased bias (2,8A) for ~50W
Heatsinks are ~23C above ambient. Note: Also the front and back panel are dissipating as well as the 2 panels that hold the amp modules.
I made the whole thing in such way that I could add another 2 heatsinks in the middle.
3mm plate is cut on guillotine.
10mm was cut by saw. Any rough edges I sand back if required.
Originally I wanted perfection, but I realised 90% perfection is much quicker. To get the extra 10% it takes a lot of work, which means a lot of time.
I'd rather spend that time building and listening to more amps, hence the reason for building 7 cases (42 is too many). With 7 cases I can compare several designs at any one time, and in the process hopefully learn something.
Hello everyone,
My first post in this beautiful forum.
Just my little 50kg Aleph J. Black and beautiful. I am thinking of a status LED, but until today I always know when its on by touching it :D
Right now i am looking for something smaller... the Alph Mini :D Seems i am infected by the Papa-Virus
newreply.php
AX-200
HI
I build this AX-200 a couple of years ago.
The only thing I changed are the resistors replaced with coils between the capacitors in the power supply.
Rob
