Michelson and Morley proved Einstein was wrong
In an effort to explain the shortcomings of Einsteins theories science has had to invent black holes which are conveniently invisible and virtually impossible to detect.
No.
Modern cosmology takes no account whatsoever of electricity, and yet we know it is by far the most dominant nuclear force.
No and no.
The fact that the universe is accelerating when it should be decelerating is further confirmation that gravity is not the major force in the universe.
Gibberish.
The electromagnetic force acting between current filaments varies inversely with the distance between them. This is in contrast to gravity, which declines much more rapidly, with the square of the distance
No.
That would mean that the earth would revolve around the sun where it was 8 minutes ago, it clearly doesn’t.
No.
The big bang theory was assumed to be the answer to explain why the universe is expanding. Let’s simplify the big bang theory, ‘first there was nothing, then it exploded’.
No.
The big bang is supposed to have occurred 13.7 billion years ago yet there are stars that are known to be older than this.
No.
What I mean by the temperature of the sun being not as hot on the surface is that if we accept that it is nuclear forces that generate the suns heat then surely any holes on the surface of the sun would expose higher temperatures, not cooler as observed.
They are not "holes" where the hell did you get that idea?
Einstein assumed that gravity is the dominant force in the universe, yet as you say gravity is known to be a weak force by a magnitude of 10 to the power 36. In an effort to explain the shortcomings of Einsteins theories science has had to invent black holes which are conveniently invisible and virtually impossible to detect.
A black hole has no more "reach" than the mass it originated from, they are not used in any way to "explain shortcomings", that is a grave misconception.
It's not like that when a star collapses into a black hole that it suddenly gets ore massive. The mass stays the same, so the total amount it warps spacetime (and thus how much gravity it exerts) stays the same. It just gets more concentrated.
Einstein states that there is a fundamental limit to gravity, that is the speed of light. That would mean that the earth would revolve around the sun where it was 8 minutes ago, it clearly doesn’t. Einstein spent much of his later life searching for a way to reconcile gravity and electromagnetism without success.
No "information" can travel faster than C, but the gravity field (warp in spacetime) created by a massive object can be seen as an extension of the object itself so it does not violate SRT. If the object "dissapears" the distortion in spacetime/gravity field dissapears with it so there is no violation.
The big bang theory was assumed to be the answer to explain why the universe is expanding. Let’s simplify the big bang theory, ‘first there was nothing, then it exploded’. You don’t need to be Einstein to see the shortcomings of this theory.
This is one of those creationist's arguments that sounds halfway logical but it's really a stupid thing to say. You don't know that there was absolutely nothing.
Between 12 and 15 Billion, but there are no stars older than this. Evidence please.
Another possibility exists: there is no explanation possible.
Exactly that. What we perceive as reality and can test is not rational at all. There are endless contradictions, virtually impossible relationships, and aspects that can not be connected properly.
What does this tell us?
It says that things are NOT what they appear to be at all.
The very idea that some sort of abstract (and simple at that) series of numbers or equations could fully describe everything can be seen as problematic in and of itself.
The rationality of "the universe" is merely an assumption upon which the investigation proceeds. Is it warranted??
_-_-bear
If the universe is one big illusion, it does seem to follow a set of rules. It doesn't matter if it's an illusion or not if we find out what those rules are.
For instance, if the designer of your old cathode ray tube monitor or TV that you may own or have owned had not factored in the relativistic effects of the speed of the electrons, then your picture would be fuzzy because the focal point would be wrong.
So illusion or not, we need these laws to make stuff.
_-_-bear
Yes, i think that we must begin to understand the deeper nature of things:
gravity
electricity
mass-matter-energy
spacetime.
This last, in my opinion, is the only and the deeper element that with different structures and dimensions generates the others above.
But how this work? :rolleyes:
Francesco
The existence of 'the universe' (as opposed to, say a universe for each observer, a 'multiverse') is another one of the assumptions which lies prior to the assumption that its rational. In the cases where our predictions work, it makes sense to hold to the assumption that its rational, but this must always be provisional.
Multiverse theory not convinced me much.
I exist now in this universe and i not thinking that i now can exist in others infinite universe. Each time that i assume a decision, i not think that i am going to splitting in different universe.
I can decide to run with my machine to north street or to south street, but when i decide to go to one street then i not go in a different universe if i have gone in the other street, as the theory tell me.
In other words this theory tell me that exist a different universe for each decision a can do, or there is a different copy of mine that go in different universe, one for each event i can do.
I think is enough one copy of me and one copy of universe. :D:D:D
Multiverse Theory is a "Theory of decisions" but facts are different.
Schrödinger cat can be indifferently live or dead until you not decide to open the box. But when you have decided to open box then there is one only possibility for the cat.
Also for a particle as electron: it is at the same time particle and wave, but if you decide to measure or to view it then one only aspect is real.
Francesco.
Check out decoherence. The hapless feline can't be in a superimposed state for that long - its impossible to isolate it sufficiently from the rest of the universe.
I tell all the girls that in the other universe, I'm a billionaire.
The smart ones might ask 'Is that one of the universes where hyperinflation came along a few years earlier than this one?'.
