Commercial Gainclone kit- building instructions
You may try adding small cap as described here: http://www.diyaudio.com/forums/audi...-kit-building-instructions-3.html#post1516522
If that won't help, try adding Zobel (Rz 2.7R and Cz 0.1uF on amp board).
If noting helps, you may be forced to add some shielding to amp circuit.
I have some amp running without any enclosure and in my listening environment it's not a problem, but with other setups it may be different.
Panic over. Wooden box is fine. No need for adhesive aluminium shielding. No need for a metal case. No need for zobels. Damned cordless house phone was the culprit. Chucking out the "throbbing" EMI. I've read they're the absolute worst for radiation harmful to humans too (ie worse than mobile (cell) phones or Wi-fi). A metre further away resolved it completely.
Many thanks to Peter and all who helped.
I have accidentally burned two mur860 in one channel. Can these to replace with MUR890? I am building Peter's LM gainclones (monoblock). Also, the LED light in the other monoblock seems to be turning off very slowly. It took a minute for it to turn off. The rail is at 27v. transformer is 2 x 25vdc. DC offset is at 80mv. what is wrong?
In picture 011.jpg, the bottom two mur860 are the ones which burned and the ones above are the mur890. The LED is shown in 013.jpg. I used a 62k resistor at R3.
LED turns off slow because you have capacitance that keeps it glowing until the capacitor is completely discharged. If you are using a regular LM3886 or LM3875 you do not need better than MUR860. How in the heck did you destroy one of those diodes?!
IF you have MUR890 laying around it will do the same job as the MUR860
Yes...but lights goes off in 1 minute???
Sigh..it was a stupid mistake...the v+ and the pg+ from the psu was suppose to connect to the v+ and pg+ of the main board....and i connect the pg+ of the psu to the 'chg' of the main board...and the v+ of the psu to the pg+ of the main board. Heard the transformer buzzz but I thought it was humm and then 'pop'..spark flew and i have two destroyed diode. i am using the LM3875. Can I sub the two mur860 with the mur890? I have the 890 but not the 860.
pmchoong, please make sure of these things:
1: As with the other gentleman your rcas should be insulated from the chassis. (its okay that they touch but it can cause ground loops which will buzz)
2: Do you have signal going to signal or do you have signal and ground switched around on your RCA plugs?
3: this buzzing can be caused by bad solder joints and if you made your own RCA cable there could be bad joints there or you could have bad joints in your input RCA jacks on your chassis.
4: solder joints could be bad at signal input to amp boards.
That covers bad solder joints I guess. Another thing to try is this:
With ground loop problems sometimes just touching signal wires, heatsinks, volume pots with our fingers can cause the hum to increase and then we know we have a grounding problem. With the amp on try this out. Wiggle the wires, touch the volume pot, touch the heatsink. Does the hum/buzz change when you do this?
Take some pictures. Lets see whats going on here.
The fact that it gets louder when you connect the RCAs makes me think that there is a bad solder joint that goes to ground. Check extra carefully for that and if you DIYed your own preamp check that on another piece of equipment to make sure its not part of the problem.
Uriah
Nis,
This might or might not be a problem. If you want to know before you spend the money then simply remove them from the chassis and plug them back together and see if you get the same problem.
Uriah
The only problem, yet, is that I need to drill some bigger holes in the chassis. I haven't actually done any soldering apart from putting the components on the board. I was just asking because Peter's connectors seems to be grounded and all connectors I could find around where I live were not isolated from the chassis.
I have ordered a pair of these: Pair Gold Plated RCA Phono Chassis / Panel Sockets on eBay (end time 25-Aug-10 19:41:50 BST)
