500 W amplifier with mosfet that made him one? the sound?
Amplifier with mosfet in thread:
http://www.diyaudio.com/forums/solid-state/162043-mosfet-amplifier-irfp240-irfp9240-31.html
have very good sound and stability.
hello sir, can u show me urs projects pics.......
I share circuits of my old discounted projects, I don't want use forum for advertising my commercial products. You can see my B250 in post #40.
Hi Mr Apex..im interest B500 dan H900..for bridge mode in B500 dan H900..how much outpower in 8 ohm dan 4 ohm ?..sorry my english..thank you ApexBrigge and Soft-start
B500 1000W/8R, H900 1800W/8R in bridge mode I not recomand to use 4R load.
Hi..Apex... For B500 can I used tranformator with secondary CT-62VAC?? Its too big? If I will used this tranformator, which componen must be change?
Pozdrav
Use 5 pair of outputs with 2x62vac transformer, no need to changes only use 4k7/2W resistors for 15V zeners.
Pozdrav
Hi Mr. Apex, can share with me the PCD layout and parts of D14 amp.
You can find in my threads pcb layout and part list for D14.
Pozdrav
Thanks Apex..I will try its...
Pozdrav..
Thanks for the reply Mile.
I can't find BDW84D & BDW83D in our place. Do you have alternatives on this?
TIP142/TIP147 or any over 100V darlingtons.
you can go alexan many darlington output thereThanks for the reply Mile.
tip142/147
mj darlington more power mj11032/11033 300w 120v t0-3 case
regards
Thank you so much Engel and Mile.
To Mile, can i use a 38-0-38 volts transformer if i use tip142/147?
No, I suggest you to use 30-0-30 volts transformer with TIP142/TIP147.
Please send posts about this amp in thread:
http://www.diyaudio.com/forums/solid-state/164093-100w-ultimate-fidelity-amplifier-32.html
Thank You verymuch Apex..B500 1000W/8R, H900 1800W/8R in bridge mode I not recomand to use 4R load.
- 500W PA amplifier with Limiter
