OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli
My main system is comprised of lm3886 chipamps. i have built various of these and are happy with their sound. I have had a krell collector here and he brought his ksa 50. To be honest we could not really here a difference between the chipamps and his ksa 50.
and he was very happy with the performance of the chipamps.
I guess this might be due to my speakers not being the most expensive. would like to try comparison between these on different speakers.
I am currently using a dual 1218 and an el cheapo behringer dj mixing desc running into my rotel rsp985 connected to the chipamps running wharfdale valdus 400 loudspeakers.
I want to take the behringer mixer out and get a better riaa preamp , that is why I decided to build a tube preamp and came upon this circuit.
I am not a crazy audiophile. I love building amplifiers and equipment.
I can't spend massive amounts of money on them.
I do realise that a very expensive attenuator will possibly have 0.0005% less distortion than using a plain 100k alps potentiometer but in the end everyting is limmited by my speakers. I will upgrade my speakers in the next 5 to 10 years.
These are the reasons that i will be happy with a carbon track pot ,because i honestly don't think i will be able to hear the difference.
One day everyone tells you you must use carbon resistors the next everyone says metal film.
I build my riaa stage acording to the original desing on the website using
100nF and 33nF wima caps and 4 2.2uF mkp10 wima caps and 1% 0.5W metal film resistors.
Listening to bread now.
It sounds great! Resolution (if that is a good description) is awesome. I am very happy!
On the behringer for some reason i keep on having to set the bass and treble to get clean sound, this needs NO filters. It sounds like I want it. Zero bass or treble need to be added or cut.
Current setup is
dual 1218 - tube preamp - rotel rsp985- lm3886 - warfedal valdus 400
In the next few months it will be:
dual 1218 - tube preamp with alps 100k attenuating - ksa 50 amplifier - valdus 400
Currently listening to my best of Bread Lp which is sounding much better with the tube preamp!
Is 40C too much for a toroidal transformer?
diyAudio Chief Moderator
Joined 2002
Current setup is
Vinyl, bell-bottoms & lava lamps. I dig. Watch to not touch the reg or phono by accident when the room's light dims and the riffs play.
40C is quite OK for a toroid.
P.S. I would not be surprised if Smokie liked The Bread. OK surely The Ramones liked Smokie.:)
Hi Quanghao,
Have you sent the replacement boards yet?
John Caswell
i was sent you 2 weeks ago!
There are some Member get PCB I sent again, and next day they get it again one more, They tell my, I'm very thanks!
I think your address ?? can you sen me other address and your phone number please? I sent it one more!
Thank for help!
Quanghao
