900W H-class PA Amp with Limiter
Hi Apex,
How about a LDR and a LED encapsulated in a dark small tube facing each other to form a modified NSL32, will that work fine for the limiter circuit? Any suggestion instead?
How about the MOCxxx series?
My friend have hard time looking for this opto coupler NSL32 in the Philippines.
Thanks & Regards,
>Joel
Hi Apex,
Thanks & Regards,
>Joel
Optocoupler with resistor output can be used for limiter, and you can made some with led diode and optoresistor,
Hi Apex i want build h900 with double step diriver plz guide the circuit
There is no H900 with double step driver, use circuit from this amp,
hi apexaudio
greetings how many watts is this circuit can you tell me answer of this
question for general knowledge
1 10 pairs of 2sc5200 2sa1943 at 70 0 70 volt dc how much rms output power will be
produced emitter resistance .22 5 watt
thanking you
andrew lebon
With 70-0-70V DC you can get about 130Vpp or 46v rms, output power will be 530W on 4R load,
hi apexaudio
greetings is the 2500 watt circuit for diy understood no pcb for
this project can 2sc5200 be used in output stage for same power reason i ask
in my city for one pair ofmjl4281 we can buy 7 pairs of 2sc5200
1 is it 2step or 3 step voltage supply for 2500 watt circuit
2 you told me with 50 100 150 50 100 150 supply it is possible to get 2500
watts from 10 pairs of 2sc5200 3 step hclass
any schematic for diyers no pcb no problem can make pcb with hand
thanking you
andrew lebon
