Mr Pass' website still down for maintenance. Is the Pearl 2 available by now?
I'm intoxicated by vinyl lately, hence this would be great phono to go for.
I'm using 05.mV MC cartridge, do i need a stepped up trans to use with Pearl 2?
I'm in for the PCB & PS board too.
Thanks.
Thanks.
Hi
Still waiting the article.....
meanwhile the topology of 2nd stage is a little bit similar to this:
EB-602/210 Headphone Amplifier
So we can change it to dual supply?
cheers
Coffin
cheers
Coffin
OK, OK, I'm getting anxious... I never was that good at waiting.
I'm finally getting a "good" turntable and cartridge. I know my poor mediocre VP129 sorta tube, cheap opamp phono stage isn't going to cut it (tube doesn't amplify, only serves as a poor input "buffer") . I thought I might mod it. It could easily be improved, but it's not worth it. So for now I will be building a decent little opamp phono stage with a good power supply.
What I'd really like is to build this pearl 2!!! (at least I'll have the opamp preamp until I can get this one together) This seems like it would nicely match the new 'table.
I know good things take time. I assume it's in the final stages of getting ready to release. I'm just so excited to finally have a good vinyl setup!!
industrial area.
ONO South-East could use a renovation job.
See Dragan's post on polystyrene caps from Oppermann at the Analog-Forum. (1st half Dec '08)
Dragan measured the Siemens KS25 caps to be within 0.5% tolerance, some would say that's notta bad for +30 year old foil caps.
The boxed types are much easier to solder than consumer grade axial styroflex craps.
A couple of other colors/numbers =>
Are we really making specific requests here, or are we just pitching in with posts that show that there is a groundswell of interest for the Pearl II phono pre?
We are enthusiastic about the Pearl 2's release, we showing our interest and appreciation as well as giving them (PassDiy) a general headcount of how many boards and parts to order. Also, how much $$$ they are going to loose, by selling boards to us heathens and infidels.
Hey, they said it not me! I'm only repeating what was already said!
Thank you PassDiy
Ron
- Pearl Two
