Building a 1000W @ 8ohms class D amplifier from zero
These are just sensing, (some not good) ex 1= problem at resonance point.
where is the method (for decrease current on amplifier)?
instead switch-off driver?:)
Yeah they are sensing methods and they can be implemented to control gain of amplifier rather than switching off the amp.;)
If you sense the current thru inductor and then convert it to dc Or sense from other mentioned methods, you can use it to limit the amplitude of input signal thru compressor methods using LM13700 or NSL-32 opto LDR.
You can also feed the sensed voltage across the current sense resistor at output to the inverting input of input opamp/comparator to limit it directly.:D
Why do you want to do this?
If you just want to understand Class D design, why not start small? A nice 100 Watt amp is an easier problem and they are handy.
Why do you need over a kilowatt? Do you have some speaker that can handle such power? Could a different speaker achieve your sonic goal with less power? If it is to drive an array of speakers, why not give them an amp each?
Finally, if you really need over a kilowatt into 8 ohms, why not just buy a pair of Hypex modules -- rated 700 W at 1% THD or 600 W at 0.04% into 4 ohms -- and bridge them?
There is no limit and it is DIYers Forum! :vampire2:
realization 8 Ohm is 1000 watts .
full bridge
lm311 , 72AC00 , ir 2010 ,irfp90n20 f-200 kHz
90v (rms) 4 Ohm
80v ----- 2 Ohm
98v------8 Ohm
per 1 channel f- 400 Hz
lim-lm13700
