OLD THREAD DAC End by Andrea Ciuffoli
thanks for the reminder....that means I need a set of 2.2R and 1R and 220 and 200R trimmer for this project....going shopping and broke again...
What is the AC voltage for the heater AC input?
Try to keep the resistors on 2.2R so you help the regulator. I suggest to select LT1085 for regulator and not the LM338.
The multiturn 200R trimpot is standard value and easy to find. 220R is not standard and you cannot find it, but the value here is not critical.
Replace R11 1K with 560R so you can adjust the voltage to 6.3V
So:
1) mount 2.2R resistor
2) mount LT1085
3) mount R11 560R
4) mount 200R trimpot
Do not connect the I/V board with tubes at this stage because if voltage is around 7volts you may destroy the tube.
So load the power supply with three 1.2R 5W resistor in series so you load the power supply like having the tubes connected.
Now adjust the voltage to 6.3V
If relay chattering then replace 2.2R with lower value.
When everything ok do some power cycles and check if relay engages ok. If you have the scope check the ripple on output. You must load as I told you before you check.
After all this you can connect the I/V board (of course you need to adjust the High voltage side to 270V)
I hope it helps.
I think i will use 9V since you said it's ok....
I hope it helps.
You mean load at the heater and B+ section at the output with 3 resistors to adjust the trimpot....????
If the voltage slightly exceed to 270v+/-30v after adjusting the R1, R2 & R3 value would this be a no no...???
Hi Quanghao.
Cangratulations for the interesting project.
I have some question for you.
1.Is it really necessary to supply pin 18 (M2) to a dedicated regulator(VD4)?
If so, why don't you connect also pin 24 (M1) to VD4 instead of VD3?
in this question, im sorry , I do not answer! ( there are on member ask me that)
I was the one who asked. IMHA it's a waste of part... Just put it to high.
Can someone please outline to me what i need to do in order to run 6n6p tubes.
What voltages do i need (my input transformer is 300v, and my heater is 9v (5amp).)
What modifications are needed in order to run these valves, if any.
voltage wise, and heater wise the specs are pretty much the same.
However, the 6n6p has a completely different pinout, so you will need to either.... air wire your sockets, or cut traces and reroute using wire to the socket.
the pinouts couldnt be much more different... frustratingly.
My mistake...perhaps this is the right way to load the heater to adjust the voltage to 6.3V....3 resistors in series....please correct me if i'm wrong...
1. Strosek: full set
2. boudy : full set
3. ksnider1: full set
4. toufu : (IV + Supply For IV) x 2
5. ferrari: (IV + Supply For IV) x 2
6. analogdiy: full set
7. wobii: full set
8. Cobra2: (IV + Supply For IV) x 2
9. mikelm: full set
10. le´flu: just one salas reg please
Hi all! the next weed i will finis all PCB for 9-15 member !
