Self-oscillating class D amplifier
amplifier must complete and they work with any PSU.
this is the right way to solve all the necessary serving on a good amplifier.
disable the driver is correct (when the voltage starts to fall)
Now put a comparator which controls the voltage (there are many ways of course)
this circuitis lock only voltage drop.
indipendent from vc (10-15V).
tell me if you have also necessity of delay when enable SD.
To 81bas.
You have developped amplifier for you?
...tells:)
Look at your post #21 first... :rolleyes: The amp is working now, ask Vogor ;)
I have not developed any commercial class D amp, it is not my target. I am a programmer and electornics is only my hobby, but I understand some things and I try to help others in this forum to solve the problems, which I have solved previously...
Not always :) This affects the dead time. Reducing gate resistors, DT will be reduced also. For distortions it is important that the DT is as small as possible, but it is more important to avoid shoot through.
If a little to reduce R13 (6,8K), for example to 4,7K that distortions should decrease and what with efficiency it will grow?
if it is too small that there will be a through current?
treshold difference is damping.
driver voltage not decrease significative at power.:)
This scheme is a bit more difficult published in a post 68 on one transistor, what than advantage at it? It also makes signal SD for driver closing at decrease in a supply voltage and eliminates "a deenergizing impulse" what at it an operation threshold, V1 (13V) whence it is necessary to submit? Whether it is possible to replace lm339 on lm311?
