I think the bias currents have to be balanced to get a fairly low DC-offset to start with and then fine trim it with the pot.
Actually that's precisely what the pot does.
I think the reason he is running out of adjustment is that the values of R18 and R19 could be too low is his case.
I don't have any trouble adjusting mine to zero AC couple or DC coupled, but we could be using different values at some key components.
Cheers!
Russ
I use 470R But it should be ok to go up to 1K(the same value as the pot).
Hi Russ
I get the same problem on the off-set adjustment.
According to the BOM, R18/19-221R, Roff-set 10K and
I'm using 220R for R18/19, should they be changed to 470R
or higher? and What is the value of Roff-set? 1K??
Cheers
TS
Thats the values i used. I will have a mess with one fo the boards when i get time. First thing will be to try 1k for r18/19 which will give more adjustment.
Hi adamus
Will you also change the Roff-set to 1K?
I'm waiting for your test results
Cheers
TS
I got knocked off my bike by a car and am still very dizzy, so probably not ideal condition for electronics.
Hi adamus
Sorry to learn that hope you'll recover soon.
Cheers
TS
just whipped out the 221r and replaced with 2k (r offset 10k) and I get closer to dialing out the offset, but with the wiper at max anticlockwise i still have about 200mv offset. This is without the inputs shorted as i will be ac coupling.
I have asked a couple of times, but has anyone got these working other than Russ. I am sure we can get them going, but i wonder how others have differed from me.
I forgot a #4 on my list: the useage of JFET input transistors instead of bipolar, but this changes the sound quite dramatically.
Adamus, this is what I mean. The resistor R3 has to be trimmed to balance the bias currents. In LTSpice it's 6.55 uA. I can't remember what numbers it was in real life, but it was not too far from this. R25 should not be altered. Since you already have an SK170, you could at least try it on one channel. You have the right value when the DC offset doesn't vary with the turning of the volume pot.
I'm still voting for:
1. current source to the positive input
2. balancing the bias currents with "the right" resistor values + input cap
3. input cap + cap between R3 and ground
I'm sorry I looked at the wrong schematic. It should be:
3. input cap + cap between RG and ground
Its been bugging me that i couldnt get this going.
if i have anything over 20mv over r1-r6 i cant dialout offset with input caps in place.
checking over the boards, the only discrepancy i see is r11 is 15k and not 16.2k (on diamante schemetic, not the schamatic nelsonvandal has shown)
offset is not stable, it will fluctuate +/- 6 mv and takes at least a minute to settle.
- Diamante -a discrete medium power opamp
