Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
OPA1656: High-Performance CMOS Audio Op Amp
Thread Tools
Old Today, 09:20 PM   #701
JRA is offline JRA  United States
Originally Posted by MarcelvdG View Post
So if I understand you correctly:
3.4 pF, 1 kohm does not work
6.8 pF, 470 ohm works
15 pF, 220 ohm works
Any perceived and measured differences between 6.8 pF, 470 ohm and 15 pF, 220 ohm were actually differences between left and right of your turntable.
Based on that information, I'd also choose 15 pF, 220 ohm.
Do you think it significantly matters whether the damper is just inside the metal shell on the RCA connector or down on the board // the 47K?
Old Today, 09:28 PM   #702
MarcelvdG is offline MarcelvdG  Netherlands
Probably not.
Old Today, 09:29 PM   #703
Hans Polak is offline Hans Polak  Netherlands
Originally Posted by JRA View Post
Would a Wima 0.1uF MKP10 across C4 show any effect or too small? Or I have 2.2, 3.3 and maybe larger in X7R ceramic. What you say Hans?
My favourite to start with would still be to shorten C4 because this reveals most of all. When nothing spectacular comes out in terms of better behaviour or strange DC jumps, remove the short circuit and leave C4 as it is now.
Therefore the new bottom line is, if they called a halt to these festivities and I had just these choices I'd go with the "Good enough" 220R/15pF combo; use the 1612A or 1656 if they sounded better than the current favorite and well-behaved OPA627. So that's today's blog.
The OPA627 is my all time favourite in this sort of applications, so Iím looking forward to hear your final judgement.
Hans
  Reply to this post
OPA1656: High-Performance CMOS Audio Op AmpHide this!Advertise here!
Thread Tools
SAR ADC for high performance audio ADC project [LTC2380-24] Frex Equipment & Tools 242 20th October 2020 02:12 PM
High performance subwoofer filter circuit(low pass) to your audio amp rrbadrike Analog Line Level 3 12th January 2017 02:06 PM
High performance audio opamps that are currently in production Fusion916 Solid State 3 8th February 2016 07:06 PM
Profi drivers in High End audio cabinets - for the ultimate performance Bojan Hajdinjak Multi-Way 13 2nd June 2004 10:03 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
