Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC project
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC project Please consider donating to help us continue to serve you.
Old 3rd April 2018, 01:39 AM   #1021
Tranquility Bass is offline Tranquility Bass  Australia
Tranquility Bass's Avatar
You need to add an FIR filter module to your design and then load the coefficients into it, preferably from a table you have generated via some other software.
cheers
david
Old 6th April 2018, 09:51 PM   #1022
yoke is offline yoke  Croatia
yoke's Avatar
Thanks David for replay
will read a little...
But I have another question
I would like to have full control per channel
in the templates from download page we have 2way,3way,4way
but the channels are in pair, so that changes we make is automatically reflected to both chanels (L / R)
what I would like to have is like separate volume for L and R channels for tweeters or any other channels (have plans to add some subwofers so I would need more different control for L and R channel)
Before I burn something, I touth to ask if someone have some experience and
does setup in the picture looks o.k.
I take 2 channels and separate them to mono L and R ( I hope )
than take L (R) and add 4 way crossover to it
and connect those 2 x 4 channel to the 8 channel output
This way I could add different controls for each channel...I hope
so does this scheme looks fine
Old 7th April 2018, 03:46 AM   #1023
Hi Josip
If you want the channels to match up with the labeling on the back of the unit then you need to assign them to the interleave block where the ordering is such that the top input is channel 1 and the bottom input is channel 8. Always pays to check with a scope, the built in VU meter ([Main Menu] -> [VU Meter]) or a full range speaker etc before you connect up your drivers.
Also depending on the firmware version you have installed there is a level trim adjustment for each individual channel available from the menu ie [Main Menu] -> [Setup] -> [Setup Audio] -> [Level Trim].
regards
david
Old 7th April 2018, 07:34 AM   #1024
yoke's Avatar
Thanks David
( I think I did get massage over email about some software update from dsp concept but didn't install it jet...)
About labeling
could you please check the diagram, did I assign it correctly
Old 7th April 2018, 09:29 AM   #1025
yoke's Avatar
and it looks like I have some other firmware instaled as I dont have ''level trim'' under ''setup audio''
have like;
-connectivity
-dac
-trigger
-spdif
-line in 2 assigment
(don't know should I upadate firmwaer, if posibile, or don't tuch any thing as long as it working )
EDIT: just updated firmware...all good
Old 7th April 2018, 10:16 AM   #1026
Originally Posted by yoke View Post
Thanks David
About labeling
Yes you got it
cheers
david
Old 7th April 2018, 11:35 AM   #1027
yoke's Avatar
Old 8th April 2018, 07:11 PM   #1028
DSP_Geek is offline DSP_Geek  Canada
Hey David,
Still overseas? (I ask because: next batch of fully builts?)
Old 9th April 2018, 09:39 AM   #1029
Getting closer to finalizing Rev-C
ES9038-PRO design with new regulators and a whole new IV stage
Old 9th April 2018, 09:43 AM   #1030
bkdog is offline bkdog
Nice!
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC projectHide this!Advertise here!
Full Digital / CrossOver / Multi Amplifier integrated KOON3876 Class D 71 21st November 2014 12:56 PM
Multi channel Linux audio player with integrated amplifier questions. ollepetersson PC Based 5 17th March 2013 03:46 PM
Multi purpose multi channel gainclone PCB: Team project - group buy rick57 Chip Amps 14 29th March 2003 06:54 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
