Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 20th March 2020, 09:28 AM   #21
drone is offline drone  Germany
this is a very interesting project. Keep posting your results
At the moment I test some display types for my DAC case.
As I am trying to learn some more programming I concentrate on the "hardware.side" of things for now.
But would need some C++ code for reading the sampling rate (and print it out),to put in Poni's fine code base. Which I am not capable of writing by myself (for now )
Branko
Old 20th March 2020, 02:35 PM   #22
francolargo is offline francolargo  United States
@Drone,
If you want to display the signal sample rate, it can be read and computed from DAC registers 66-69. This will be simple if you use the on-board 100MHz master clock in the Buffalo. However, if you wish to supply the Cronus clock as master - i.e. like 'true sync' - that will introduce uncertainty because the DAC will slave to frequencies that are multiples of either 44.1 or 48kHz. I do not see how the DAC chip would know which frequency it is being fed, although presumably the I2S renderer *will* know what frequency is specified in the music file. So for synchronous operation, if you want to display the signal frequency your C++ software will have to read some data from whatever digital source is creating the I2S. (I have that working with Python on the BBB - sorry but no clue with C++).
F.
Old 30th March 2020, 05:06 PM   #23
Hello Poni,
hope you are well.
Any chance you found some time for the "sampling rate" thing.
Sorry if I am bothering too much.
BR
Branko
C++ Easy and Scalable Software for BIII38ProHide this!Advertise here!
Scalable PSU/regulator GB BobEllis Group Buys 655 2nd June 2015 09:52 PM
Easy, simple to use software for measuring FR, impulse, etc? makingmoney Multi-Way 7 6th July 2010 09:45 AM
Easy PCB Software Bonanza Software Tools 3 31st May 2010 10:23 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
