Hi I am also a newbie and have been reading this thread for sometime. I began my build of the original version of the baby huey about a month ago and am very keen to see how good it sounds.
My question is about the Bias for the EL84 tubes. As it is unclear to me from the schematic which way round the Bias is connected. I've been doing a bit of reading to see if I can work it out.
From what I can gather the Cathode usually has a negative Bias but the grid should be negative with respect to the cathode. Otherwise there will be grid current. However, if grid is too negative wrt cathode (several volts) you come to the situation called cut-off where no current flows to plate or screen grid. In this circuit the grid is at 0 volts if no grid current is flowing. So does this mean I want the cathode to be positive? To have the Bias connected with the positive side to the Tubes?
http://www.diyaudio.com/forums/tubes-valves/72536-el84-amp-baby-huey.html#post826626
cathode pin to the top of the bias block, ground the bottom.
I've looked at the schematic of the bias blocks many a time and have only just noticed that the Blackgate 470uf 50v electrolytic cap hasn't got it's polarity marked.
Top plate ( cathode pin side ) +
Bottom plate ( ground side ) -
I am currently mid Baby Huey build and am searching this vast thread for any posts of speaker choice. It seems that some are using the uFonkens....
What are people using for their Baby Hueys?
Being a novice DIYer im looking for plans for something to compliment my Baby Huey when it is finished.
Charlie
Charlie
Thanks for the help guys.
Im using Fostex full range units in some home made horn loaded cabinets. Ordered them from Wilmslow Audio in Leicester. Not tested them with the Huey yet as its not quite finished - but they sound great with my Rodgers Cadet.
Photos of my Build: Baby Huey EL84 Valve Amp | Facebook
Booth,
That's a well thought out build, lots of useful photos for other builders - congrats.....😎
Charlie,
I'm using Monitor audio bronze, and sometimes some old Kef Coda 2's but would like to upgrade.
I was thinking of starting a separate thread to find out what speakers are attached to other peoples Baby Hueys, or indeed any pp EL84 amp, will wait and see the response here .:🙄
Ps Wouldn't mind what Gingertubes got
Charlie,
Just a quicky,
My heater windings have a CT, if i connect the 2 100ohm resistors from each side to that, do I still need to connect that to ground? Or should I ignore it and follow the schematic?
Charlie
Charlie
Just a quicky,
Charlie
You should leave out the 2 100ohm resistors and connect the CT to ground 😉
In the first time baby huey thread, gingertube says connect a 10ohm resistor from a 12v supply to the positive bias side, to check the circuit. You should read 0.4v across the resistor for 40mA current.
I am testing my circuit using the CCS winding (5v 3A) and a 470ohm resistor.
I read 5.28v across the resistor, ohms law tells me that's about 11mA current.
All 4 of my bias circuits read the same, so unless ive built all 4 wrong... I must be doing something else wrong...?
Can anyone help?
Charlie
Still learning
Can anyone help?
Charlie
Still learning
Apologies in advance for stating the obvious, but you need dc and it may be unreliable to use less than 12v
Bill
Bill
Ah.. yes.... that would be it then.
Think ill put this to bed for today and have a glass of wine
I just quickly checked with a 9v battery, read about 15mA.
Should I just continue with the build and check again when everything is in place? As I dont have a workshop power supply to get the 12v DC
Charlie
Charlie
I used the -dc output from the voltage doubler needed for the ccs, it was about -13vdc IIRC.
ps how many glasses did you have..😉
The last time I had a bottle of red I went on diyaudio and got myself "moderated"
They're very understanding here
- Tubes / Valves
- EL84 Amp - Baby Huey
