Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
Thread Tools |
#11 |
Due to the more expensive shipping and custom fees Lundahl opt are more tempting too buy.
I am looking for my system to be musical, not as I experience modern systems to convey details without feeling, as we have different references, there are no right and no wrong. |
#12 |
Those prices are so low, im skeptical how they actually make a profit. It would be interesting to do some A B C comparison testing using the same amp, by swapping out with equivalent Hammond and Edcor and Antek units and printing off the same tests for each, and recording some MP3 files of each model through a dummy load to hear anything different.
#13 |
I have bought from Matt. There is no 8 week wait. This dude ships fast!
#14 |
While on the subject of cheap transformers these caught my eye 1pair 3.5K Amorphous Single-ended Output Transformer for 6P6P KT66 2A3 tube amp | eBay
#15 |
I dunno - using a conductive house clamp around the coil doesn't look like a good idea...
Correction - they're using the hose clamp to hold the cores together, and that's OK. I've been wanting to try some transformers from MPS for a while. I have one of their power transformers, and I may pony up for a pair of the 5k HiFi SE transformers Last edited by wrenchone; 23rd November 2020 at 07:48 PM. |
#16 | |
#17 |
The link says Amorphous.
Then it says: "The use of imported second-hand amorphous alloy sheet winding" I never knew that a sheet of material was 'amorphous'. Perhaps something lost in the translation from Chinese to English. I am not a materials expert. But I never desired to purchase any amorphous core. I missed that boat of opportunity. |
#18 |
It looks like genuine amorphous core, although I wouldn't by this. Looks like a 1W OPT @25Hz core at best. This is why it's cheap
#19 |
And you are right. I bought and measured them. You do not need 25 Hz from a small amp, so for 2-3W it would be good.
!!!Warning!!! Single Ended Class-A-Holism is addictive!!! |
#20 |
Got the spud amp built, 3.5W output. The -3dB points are at 30 Hz and 30 kHz, though there is a bit of distortion under 40 Hz. The tubes are 6T9 so it's semi-comparable to my 6SL7/6V6 SE amp with Edcor GXSE-10 OTs. At similar volume, I can't tell any significant differences.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Renovating budget speakers on a budget | HaerdenC | Construction Tips | 6 | 25th January 2018 06:13 PM |
Budget DACs for digital crossover output? | Kev06 | Digital Line Level | 27 | 4th April 2017 04:33 AM |
$100 budget for output of Buff II | nightanole | Twisted Pear | 7 | 14th November 2010 11:48 PM |
Covers for budget output transformers | leadbelly | Tubes / Valves | 8 | 31st July 2008 05:22 PM |
Surprising Output from a "budget" project | musgofasa | Subwoofers | 10 | 19th March 2008 06:13 PM |
New To Site? | Need Help? |
