6C4C in PP (Loftin White)
The year 2018 is almost over. I promised myself that I would do another amplifier - a prototype. I have material in stock.
I plan to be finished by the end of the next week.
scheme:
Wow, is that an autoformer/center-tapped plate choke with ~2000H inductance? Or are you using two separate 530H chokes?
Each choke winding with DCR of 3.1k ohms, 16.66mA drawn across each, that's a lot of heat dissipated by the choke(s), is it not? Something like 0.86W dissipated in each winding?
because of the DC cancellation there is no need for a gap (or a very little one), so inductance goes up very fast! Just like a PP OPT vs a SE OPT.
Wow, that PP anode choke is a real beast. 500H per winding. Really nice. I wish there was someone in the US who was making something like that available commercially. (Maybe there is but I don't know about it?) '
Suggestion
As a suggestion, try removing the 100uF cap bypassing the 3k6 cathode resistor to the output stage. Put a 40uF pp cap from the B+ to the junction of the cathodes, ultrapath Elliano style. Might have to tweek the value but I found the sound much better than the present 100uF cap arrangement. Attached is Thorsten Loesch's drd pp with the suggested cap arrangement.
Great design by the way, simple and elegant.
That's excellent.
I used to have a simpler version of that kind of amp running. It had a 5687 per channel, run as an LTP with CCS in the tail, with the primaries of a push-pull EL84 output transformer being used as plate loads for the 5687 LTP. That was then DC coupled to a pair of 2A3s in push-pull driving Tango NC-45-5 OPTs. It didn't have enough gain to be used without a preamplifier. I had that amp running for around 25 years, but then it started to make weird noises, so I retired it. It did have a very attractive sound, though.
Yours is a much more highly refined take on the idea. Really, really nice. I'll bet it sounds great.
Those amplifiers look wonderful!
I bet they sound real good.
But . . .
I always thought that a Loftin-White amplifier was a single ended 2A3 with the driver DC coupled to the 2A3 grid.
I was looking at this thread to find a Loftin-White amplifier.
I did not know that a Loftin-White amplifier was push pull . . .
I guess I learn something every day.
