6J1 China preamp thoughts
I was thinking about making a hole in the tin case, but I just cut the switch and threw it away.
Hello,
I'm trying to use it as a portable headphone amplifier.
I don’t know anything about headphones and headphone amps but I wonder if the output impedance might be an issue.
Someone in the massive FX thread on AK took some measurements at different frequencies and reported that:
For the Tube 01- Output impedance: 2.87K (100), 2.64K (1K), 2.64K (10K)
Wouldn’t this indicate that, ideally, the impedance of the headphones should be 10x higher or ~26k? I was under the impression that they are typically 600 ohms or less. Not sure how that might affect the sound quality.
I don't know much about impedance (I'm studying), but the output is very weak to use as a headphone amplifier.
Korea(where I live) has the same smartphone earphone volume regulation as the EU, so the output is 1/2 compared to the US. So I'm thinking about adding an additional D-class amplifier board.
After buying something that cost 10x as much and after weeks of trying to get rid of serious hum (without success), I grabbed one of the cheap FX Audio Tube01 pre's.
It is single stage so inverts absolute phase so swapped P and N at each speaker.
Using a 50va 12vdc linear supply with it, but was not happy yet so proceeded to make some little changes.
Re-housed it and bypassed the input and output caps with copper foil caps and silver foil caps, and used a 21 step SMD attenuator (the stock one was a little plastic wiper pot but unsuitable being a linear pot). These were all parts I already had in part draws here.
I tried replacing the first caps that are after the volume pot with wire links, but that gave me a bit of DC on the pot.
Popped some Voskhod 6J1P-EVs in there and now I'm happy with it.
IMG_20250201_215126_116.jpgIMG_20250214_160851_456.jpgIMG_20250205_203354_460.jpgIMG_20250205_203404_560.jpg
Reactions: jcalvarez
