I'd be most grateful if anybody here could provide a copy of the 5AR4 power supply schematic for Poindexter's Musical Machine. The web is rife with the sand version, but the "new and improved" schematic seems to be lost to the sands of time (and yes, I've already searched this forum). The Wayback Machine has numerous references to his old site, but many of the schematics are missing - including that one.
And while I'm thinking of it: was there ever a specific schematic for the 6V6/6GK5 version of the MM, or was the builder just supposed to take the 6GK5 stage from the EL34 PP schematic?
Enquiring minds want to know...
Tube PS schematic in this post:
http://www.diyaudio.com/forums/tubes-valves/136562-pp-el34-6l6-circuits.html#post1713637
6V6 predates EL34 version. Original website still up, not sure if a mirror:
THE MUSICAL MACHINE; vacuum tube electronics in the service of art.
EDIT: Here's a version with 6GK5 & 6V6:
http://www.diyaudio.com/forums/tubes-valves/149211-6v6-music-machine-build-help.html#post1904511
Thank you, Leadbelly! I'm grateful. Embarrassed, but grateful.
I've previously looked at all the links you provided on a new PC I just built, but with no luck. This morning I opened them using the browser on my phone and voila - the schematics on the links magically appeared! It turns out my PC's browser isn't happy with my OS, and that was preventing many of the graphics from being loaded.
D'oh!
D'oh!
There are newer versions of the MM circuit, specifically using 6GK5 as the long tailpair and including a CCS as the tail load. I built this one on a breadboard a few years ago and it sounds really nice.
https://www.diyaudio.com/forums/tubes-valves/149211-6v6-music-machine-build-help.html#post1904511
There are also versions using EL34 and 2A3 output tubes. I built mine with 6B4G which is a 2A3 relative.
Good luck with you project,
John
John
John
Could you point me to the 2A3/6B4 version? I'm curious.
Thanks,
Jim
Here are a few links:
an early DIYaudio discussion: New project; Musical Machine
You should be able to adapt the triode 6V6 version for 6B4G or 2A3 with the addition of an appropriate filament transformer for each channel. I dropped the B+ on mine to 300V. Can't find the official 6B4/2A3 version right now.
Am attaching my schematics. You don't need the grid chokes on the output stage. Just use an appropriate grid resistor based on 6B4 or 2A3 data sheets or maybe the 6V6 original schematic.
John
John
Kind of a silly waste of time argument. I used the exact driver stage from the later "versions" posted by Poindexter. There is a 2A3 or 6B4G schematic out there somewhere that gave me my original impetus to build it. So the only real difference is the grid chokes. This is the DIY tube forum after all so the terms used to give attribution to the original idea are just trivial semantics.
I believe it was the first version published by Poindexter using 5965's for the LTP. Seems like I remember him saying he liked the following version using the 6GK5 LTP better. His original web page is still available which describes the original version as shown in post #2 above. And I'll refer it here as well.
http://ekingsbu.users4.50megs.com/blurb2.html
He did. And he gave me a matched pair for the inputs of a 6V6 amp I had. They are a good choice.he liked the following version using the 6GK5 LTP
Are those single triode?He did. And he gave me a matched pair for the inputs of a 6V6 amp I had. They are a good choice.
- Tubes / Valves
- Poindexter's Musical Machine:Tube Power Supply Schematic
