boutique capacitor haters
Is not really a piece of wire .What about the coupling nonpolar caps filtering the signal . I have 2 in Technics SU-3500 that are playing the high freq. Right now I listen thru some 47uf Nichicon ES caps. I think is to much . For such position using an electrolytic is unacceptable sound being to unnatural because of Resistance Rs, Inductance Ls, Capacitor Impedance Z, DC Leakage and other factors. Replacing those with some proper film will create a more warm sound retaining all the details but with less fatique
What you say may or may not be true, as I am not really qualified enough to comment, but what does concern some, if not all of us, is your ranting into the ether. Not good for you, and maybe you should talk through what is bothering you with a terrestrial based friend.
As has been said - nothing to see, move along - end of post. ToS
